F-1 16 X 6 wheels tires
I have a set of Wheel Vintiques 14-6655334 that I bought from Summit Racing for about $120.00 each.
Mine came in primer, but I've read that they are also sold powder coated.
Wheel Vintiques 14 Series Gennie Bare Wheels
Wheel Diameter 16 in.
Wheel Width (in) 6.000 in.
Wheel Material Steel
Primary Wheel Color Gray
Wheel Finish Matte
Backspacing (in) 3.750 in.
Offset +6.00mm
Wheel Construction 2-piece
Lug Nut Seat Style Conical seat - 60 degree
Hub Centric No
1940-48 Ford passenger car and 1940-65 Ford truck hubcap applicable.
Wheel Bolt Pattern 5 x 5 1/2 in.
Wheel Finish Matte
Offset +6.00mm
Hub Centric No
F1, F100: 16" wheels standard equipment thru 1954, optional on 1955/79 F100's, 1966/79 Bronco's, 1975/79 F150's. All 5 lug 5.50" bolt circle.
1967/79: The only wheels available were outies, so the innie hubcaps used on F1's, 1953/66 F100's won't fit / Edit: 16" 5 lug 5.50" bolt circle innies: 1940/48 Ford Passenger Cars & 1940/47 Commercials (1/2 ton truck).
Outie = Hubcap snaps over tabs located outside the wheels center section / Innie = Hubcap snaps over tabs located inside the wheels center section.
Coker Tire (Chattanooga TN) & Lucas Classic Tires (Long Beach CA & Springfield OH) both offer myriad brands of 16" bias ply and radial white and black wall tires.
