4R100 Stage1 Rebuild
Thanks Pops !! But I must say it was hard to choice what what upgrades to do with limited $$. It would have been easier on the parts end if I had more $$ to work with. And as far as skills go I have to be honest I am alittle over my head but I have read a couple books about 10x's and I am blessed to have a brother like Roland who has taught me so much about these 4R100's.
Thanks Roland for being willing to hold my hand and walk we though the rebuild. Also I must thank Darrel/ NissianDoc for his help and insight. All you guys are GREAT!!! I wouldn't have even tried to do this without the 7.3 PSD Brotherhood.
[quote=BadDogKuzz;11981541 All you guys are GREAT!!! I wouldn't have even tried to do this without the 7.3 PSD Brotherhood.[/quote]
im hearin ya there, so much i have done myself on mine and have all the confidence in the world to do any repair/upgrade..i have confedence to help people with a problem here aswell.
no question is ever thought of as silly or stupid, theres never a problem with something that has been covered before like some other sites. new people are welcomed with open arms.
im glad i sat down and googled ford trucks years ago otherwise id hate to know how much things would have cost at a shop.
this site is a credit to the helpful nature of likeminded people with a passion for a great rig. WE ROCK. LOL...
I would like to clear up a statement I made early about being over my head in the skill dept. I do have skills and I am good with a wrench and a hammer. HeHe Actually I use to make a living turning wrenchs for about 25 yrs. But where I am lacking on this build is the what and why's of how these 4r100 work and fail.
Yesterday I got to spend some time working on the trans and I only broke one thing. After cleaning parts I went to install ext. housing with a new teflon bushing that came with the kit. And before starting I wasn't sure I liked the idea of a teflon bushing, I mic it and it was .015 out of round and it looked like cheap teflon job. Well it didn't want to go in and I destroyed trying to put it in with a socket. Well I'll go with a bronze ext. housing bushing and I'll go and buy a bushing driver to install it.
But I did buy a Sonnax T36008a for installing the 1pc rear case bushing and that made it so easy to install and align the oil hole. I also used the tool to install the rear spag race. Which was giving me a hard time since my alignment pins were not treaded. The tool was money well spent.
I went to mock up the reverse clutch pack and with the wave plate I was at .062 end play. (Spec is .025-.048 and for performance .025-.030) And that is after soaking the clutchs first. So I took out the wave plate and added 1 more clutch and steel which got me to .031 end play. And ATSG gives you no specs for rear clutch pack. ATSG is better than no book but I think it could do better. Now my brother Doug from FDP has written a book on building the E4OD/ 4R100 and it is the best 516 pages of info, parts, photos, specs, modds and complete overhaul manual. It is copyrighted and I was blessed that he gave me my own personal copy. All he asked was NOT to copy I agreed so if anyone needs a GREAT manual PM me and I'll let you talk to him.
Now I am working on rear planet gears and end play to the Sun gears and Sun Shell figured out ? I am trying to blue print it as I put it together so when I get back into it for Stage2 I'll know where it is going to need to be tightened up. I am mic-ing the thrust washers, bearing, clutchs, steels and unit end play and overall end play and I am writting it all down.
Sonnax rear bushing tool, lip wizard, alignment studs
rear race install with alignment pins and Sonnax bushing installer
Now when I checked my in and out on the rear shaft I had .030 and I think I know where the problem is. The reverse planet hub was worn and scratched up where the metal thrust washer to the planet gears. The thrust washers were worn out. So I sanded it smooth and was going to use the rear planet washer shims that came with the Sure Cure kit but the kit came with shims for the 4 tap thrust washer. Called Sonnax and they don't make a 3 wide tap thrust washer shim. I couldn't believe it since anyone with a diesel or hipro is running a 6 gear rear planet (3tap washer) So I am going to just let go until Stage2 and address the issue then.
What do think is a good #'s for end play on the rear shaft ?? Anyone else who might have a clue could also hopefully give me their input too. PLEASE
Sorry I am learning as I go and I have more questions than answers.
Well I thought things were going along pretty well... I didn't have the correct bushing drivers for a few bushings so I took them to a local trans shop to have them installed. And I went to pick up the parts and I was wondering what they were going to charge me. But it didn't matter I needed them installed. So the lady said "No Charge" and I was so happy until I got home at looked at the pump bushing and the STUPID son of a B**** put it in backwards. So it would push the oil to the front seal NOT away!!!!!!!!!!! So now I need to buy a new bushing and seal. THANKS DUDE!!!!!!! This just an other reason NOT to trust or take your trans to a local Joe Blow trans shop.
But on a positive note I have built up all my units and set the end play on ALL clutch packs. I even mocked up the IM and OD clutchs and they were close to specs as far as end play. But I am going for the middle of specs but on the IM clutchs I am going to go on the tight end of spec since the IM piston has such a short throw so I am going for .030. So Monday I am ordering sizing retaining rings so I can get the end play I want. And of course a new pump bushing and seal too!!
Well the harder I try to get something done on this trans more issues I run into. I went to rebuild the accumulator with the Sonnax parts and the kit was missing one green spring.
Now as I started to try to get the old accumulator valves out they were sticking and hanging up bad. The bores were in need of some TLC or a bore resizing tool. Which would cost more $$ I don't have. So I made some home made bore honing/polishing tools. Laugh if you want but the valves now slide very nicely. I started with 400 grit and finished with 1500 grit.
Also a flux brush handle worked out nicely for holding and feeding the valve into the bores.
I also took apart and cleaned and polished the bores in the valvebody
I rebuilt the cooler bypass with the a Sonnax kit
And as far as me doing a full write up on rebuild I don't think I am the guy for that. It would be like the blind leading the blind.
I am lucky to keep my head above water on the build. But I am trying very hard to do the best I can with what I have to work with.
I'll be happy if the trans works after I fix it.
on
Thanks But I am not taking alot of photos but I am trying to take some to keep track of some stuff.
#28
I too am looking forward to seeing you and Mary at RRE and of course your truck. Hopefully I won't have to drive momma's chebie to RRE.
I really do miss driving Blackie!!! With her big wide rear (DRW) and chrome thong ( Chrome diff cover)
#29
on
Thanks Brother !! I needed alittle moral support. Techanical I got it handled now. Hopefully Monday I can get the parts straightened out. I am ordering a Tru Cool since I dare not reuse the 7.3 cooler. Transmission Parts Tru Cool Heavy Duty Tru-Cool MAX transmission cooler with externar thermal bypass Is this the one you have? And I need to figure out what way I am going with the Torque converter. So hopefully I'll be installing it by next weekend and finishing up the other modds I have started.
#30
Thanks Darrell the tool worked nicely.
Laugh if you want but this set up held the trans very well from moving around as I installed parts
Center support feed bolt shim. It comes .204 and I grinded it down to .183 to work in my trans.
Now after installing and torqueing the feed bolt I still had a .0015 distortion in the valve body mating surface. Oh by the way the first shim I did was too loose and I had to start all over until I got .183. Then I tried to do an other one and ended up with .182 So I guess I'll just let it go at that. This modd along with the other center support modds I did should help to keep the center support from moving around.
