Help, 6.4L diesel cranking, not starting, stranded
I heard from my son just a minute ago. He had it diagnosed by the Ford Dealer where he bought it. Their diagnosis indicate that the High Pressure Fuel Pump is bad, but the kicker is....... they want him to pay for a 500 dollar fuel analysis, and if it passes, then Ford will cover the test and the whole replacement cost, which does include removing the cab. If the sample fails, then he has to eat it, and pay for the repair too............. Is this standard procedure????
And five hundred dollars, where is it being tested, on the SkyLab?
Bad news.
Ford will not accept liability for contaminated fuel doing damage to the truck. Period.
Good news.
They are willing to provide proof. I don't know about the cost of analysis, but it's a really good thing that they are willing to test the fuel before a decision is made. In the past it has been done the other way. They just tell you it's bad fuel and stick you with an $17,000 bill.
Now, has there or is there ANY evidence of water in the water drain? Do you have any reason to believe that improper fuel was burned, or contaminated fuel (water)?
If the fuel is good, you are golden. This is good news.
Good news.
Too bad their's water in just about all diesel. Which is why diesels have a Fuel Water Separator. Sorry to say, but if your son does the fuel analysis, there's a high probability that he'll lose his $500. On the flip side, if he doesn't, he'll be out of pocket $10K+ for repairs.
That's a first I've heard.
I'd start by asking the reasoning for testing the fuel. I'm assuming their checking water content. If so, Check into Polaris labs. They offer a test for diesel that includes water %. Only 28 bucks. I'm sure their are others. Maybe you can get a test done there before dropping 500 bones for theirs.
Now I'm thinking that Ford isn't looking for water. I'm gonna go out on a limb and say that they are thinking sulfur content. Maybe there was fuel other than ULSD. Off road diesel maybe? The test that includes Sulfur PPM is $729 from Polaris Labs.
Keep us updated!
My son says that if there is a fuel contamination problem, he's going to ask Ford for a list of just where to buy approved fuel, as he has not put any additives in the fuel, and hasn't seen any warning lights, other than the wrench after it wouldn't start.
I will keep you updated. He is going to ask for a sample for his own, as he may have access to getting his own test done. He said that the Ford service techs assured him that checking the water separator is something that they have done on each of his services, and so far, have not noted a problem. He also said that he's never seen any service engine lights, till it wouldn't start!
I thought the pump on the 6.4 was not considered to be vulnerable to wear scar numbers like the newer 6.7's are?
Some folks believe the Bosch pump on the 6.7 is operating outside its design parameters with the wear scar rating of US ULSD lubricity. I also thought that the pump on a 6.4 is a Siemens? And, not as fragile?
I do a fuel injector cleaner once in a blue moon.
Latest update on my son's truck is that the truck was disassembled on Friday, and sent information to Ford. They indicated that they, "didn't see or find any signs of contamination, but that Ford Corporate makes the final call". Ford requested additional information which has been sent, and an answer is expected Monday.
#28
Did your son do the fuel analysis?
#29
#30
