Archtaan's build thread. '10 conversion, mirrors, the works!
Old 08-03-2012, 02:34 PM
04fivefour's Avatar
04fivefour
04fivefour is offline
x2 on those totals I want this so bad
  #47
Old 08-03-2012, 02:39 PM
archtaan's Avatar
archtaan
archtaan is offline
Well in that case i may as well post up. Ill dig out the receipts tonight.
  #48
Old 08-03-2012, 04:50 PM
archtaan's Avatar
archtaan
archtaan is offline
2008 RA Bumper $1500
12,000# Winch $1000
Lightforce lights $300
Piaas X4 $450
Ford Hood, Fenders, grill, grill braces, 08 hood struts, bump stops, primary and secondary hood release system, 2 piece fender emblems, 08 fender liners, 08 wiper cowl, 08 wiper motor, all new ford fasteners and hardware $1800
4 square feet 3/8 500B steel for custom bumper mounts to 04 frame $200
Paint $450
Recon Projector lights $650
Sawzall blades, plasma cutter tips/electrodes, weld wire $35
Misc rod, wire loom, square tube, nuts, washers, wiring, etc. $50
Busted knuckes - x 10 - free
So actually closer to 7K I guess. Less if you use a factory bumper. You would need the bumper brackets too. I guess around $600 for those parts < the lights, winch, bumper etc so it would be A $3800 or so if you have a plasma cutter/cutoff tool, welder and such.
It could be done for a lot less though, but I splurged for a lot of extra's and only used Ford parts. A Ford hood is $600.00 while a CAPA hood is like $200.00, same with the fenders.
  #49
Old 08-03-2012, 08:42 PM
04fivefour's Avatar
04fivefour
12,000# Winch $1000
Piaas X4 $450
Paint $450
Where all did you get the parts from?
  #50
Old 08-03-2012, 08:48 PM
archtaan's Avatar
archtaan
archtaan is offline
I got the Ford parts from the local dealer, saves shipping.
The bumper came from Road Armor, headlights from Recon, steel from local shop, misc parts from auto parts store, home depot and such.
  #51
Old 08-03-2012, 09:15 PM
7.3 Monster's Avatar
7.3 Monster
7.3 Monster is offline
Thanks for the detailed post . I'm sure others where wondering too.
Which one of the lights you listed is the regular front head lights (or are they after market HIDs)?
I could probably get a lot of those parts off junk yard trucks and on Craigslist for a lot less.
How difficult was this project (Ive fix the door locks and changed the running boards but nothing this big)? How many days did it take?
I have all the tool I will need except the plasma cutter and welder.
"Busted knuckles" lol. No pain no gain
  #52
Old 08-03-2012, 09:39 PM
archtaan's Avatar
archtaan
archtaan is offline
Mine are aftermarket HIDs from Recon. 08's run about 200-300 from what I have seen.
  #53
Old 08-04-2012, 06:26 PM
7.3 Monster
I notice you removed the stock plastic gold trim that was glued around the truck. How hard was the trim to remove and did it damage the paint?
Looks better with out it since yours is blacked out.
  #54
Old 08-04-2012, 07:55 PM
archtaan's Avatar
archtaan
archtaan is offline
Not hard at all. Its just double sided tape. Pull slow. No damage. The rear quarters will have the lower mounting holes that can be covered with he factory XLT stone guards. I can post pics if you like.
  #55
Old 08-05-2012, 03:25 PM
7.3 Monster
Looks great! Lot of work to make them fit.
I plan on going down to the junk yard to see if I can get some of the parts for the front end conversion soon. Hopfuly I can keep my budget lower than 7k .
  #56
Old 08-05-2012, 03:27 PM
archtaan's Avatar
archtaan
archtaan is offline
You should be able to do it for 1/2 if you don't go crazy with the bumper and lights!
  #57
Old 08-05-2012, 03:51 PM
land yacht's Avatar
land yacht
land yacht is offline
Nice looking X...I will keep an eye out for you on the road in VA...subscribed to this.
  #58
Old 08-06-2012, 11:46 AM
04fivefour's Avatar
04fivefour
I wanna do what you do for a living
  #59
Old 08-06-2012, 06:11 PM
LunaticSVT's Avatar
LunaticSVT
LunaticSVT is offline
archtaan. Is that front bumper for the new f350 or is it one of the older styles? I only ask because I have one of the Fab Fours and it looks almost identical to the one you have less the bar.
NVM - Just read it. Durr. 2008 model. I wonder if I could get away with my 05 FF bumper with the 08 front end. hrmm
  #60
Old 08-06-2012, 06:27 PM
liftnw8z's Avatar
liftnw8z
liftnw8z is online now
(CL) Team Brahma
Looks like the rear side trimming is giving you a good fit with the rock guards. My rule always is that my cutting is always straighter when I drink...lol.
Quick Reply: Archtaan's build thread. '10 conversion, mirrors, the works!
