Archtaan's build thread. '10 conversion, mirrors, the works!
#136
Vendor forum...1A Auto
Here's the set I bought: 1999 Ford F250 Truck Super Duty Mirror Power Heated Signal & Clearance Light Telescoping Upgrade Pair at 1AAuto.com
Another thread: https://www.ford-trucks.com/forums/1...l#post13176099
Stewart
PS - Thanks for fixing the links, Tim!
Stewart
#137
Stewart
Stewart
#138
Sure, Ill rehost them. I cleaned up my PB account a bit so that probably killed the links.
The EE has mirrors sometimes. Also some of the guys may have gone with an aftermarket one. Stewart perhaps?
The molding is exactly the same, as is the bolt locations. The only difference is the wiring is a bit different.
What is an EE?
I saw the other gentlemen posted links! Thanks! I am looking for Powertelescoping and folding - Anyone know if I can get a pair for under $500?
#139
Its the online classified ad that is on this site. Scroll down on the main forum page to the marketplace section and see if any are for sale. You can also do a want to buy as well.
#142
#143
Stewart
Stewart
Will these work with an '01 X? I've read that the connectors have to be replaced on anything older than an '02, but I see that these mirrors come with a round connector as well. Since I really don't need the power telescoping ones, these will do very nicely! Also, are both the upper and lower mirrors heated, or just the upper?
Monty
#144
#145
#147
Even though my mirrors now have the turn signal in the mirror itself, I will have to find that wire and tap into it for the turn signals? Is that correct?
#148
Yes...I believe 2002 and above had turn signal wiring already in the wiring going to your mirrors even though that year's mirrors didn't have turn signals. For 2002 I had to run wiring just for the running lights on new mirrrors.
I used this thread as a guide:
https://www.ford-trucks.com/forums/1...tallation.html
#149
Stewart,
Monty
Monty
Here's more info for ya from another thread...
Sometimes the most obvious way to answer peoples' questions alludes me. I did a face palm this morning when I realized I could just feel them to see if they are warm.
Put my hands on them this morning on my way to work and both mirror elements are heated! They worked well at clearing away the morning haze that was on them.
....more info there
Stewart
