Auto trans. linkage broken, help!
#31
#32
Received 5,160 Likes
on
#34
on
#35
#36
Oh well, I took the pan out, everything was fine inside and around the MLPS, I tried to calibrate the lever several times by myself, then got a bud to help me by holding the lever in D while I moved the linkage near the MLPS to set it in D... I got it there, but it still shifted roughly, and it was quite a task to get the lever in P (I was risking breaking the new shifter tube). We kept trying and in one of my attemps I moved the lever at the MLPS all the way to P. After that, the lever at the MLPS and the one at the cabin were disconnected, so I think I broke the cable, which would confirm my early suspicion. The shifter tube broke because the cable stretched, and my attemps to put the lever in P placed enough stress on them make them fail (even though it was at different moments).
I guess I should try this, as the cable didn't look like it was broken... just in case...:
http://www.supermotors.net/registry/media/434182_1
But I do have a question, how do I remove the cable from the ball stud? I was looking at the thing and I have no idea, don't want to try something and break the cable if it really isn't broken or hurt something else.
#38
#40
The ball ends just snap off.. trans end has a snap lock that fits in a bracket, just squeeze the tabs on the back side and it will pull out the front of the bracket. The inside snap-in end comes out the top of the bracket, the plastic part has a tab that snaps in a hole in the metal bracket, a small screw driver pushed under the tab will release it....
You are going to find your break about 6 to 10 inches from the top end of the cable, that's where they break because it is making a tight loop...
#42
on
#43
#44
#45
on
