6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Viair system installed. Love it!
Old 05-25-2012, 04:21 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
Originally Posted by senix
I solved the chuck problem with a trip to home depot.
Maybe I should've went across the street to Home Depot!
Old 05-25-2012, 04:30 PM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
I have several different chucks all modified with quick disconnects. Switching is a breeze both for the truck or in the shop.
Old 07-28-2012, 09:52 PM
obiwan kenobi's Avatar
obiwan kenobi
obiwan kenobi is offline
Gave you some positive rep, I know the idea wasn't yours but you your work here and thanks to you I was able to make the same install on mine this weekend. Now the hard part, plumbing and wiring the thing.
Old 07-29-2012, 06:41 AM
golfmedik's Avatar
golfmedik
Thanks for the reps! I've always wanted on board air. With the 5er and air bags, it gave me the perfect opportunity to do it. Absolutely my favorite mod. Good luck on your wiring, not really that hard.
Old 07-29-2012, 09:18 AM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
That's a great looking install. You will love the convience. I had a similar set up on my 7.3. I also bought a piece of sheet metal and a couple bracketts and fashioned a cover under the tank and pump to keep them relatively dry on rainy days. It protected everything quite well. Would also keep the slush off if you live in that kind of area.
Old 07-29-2012, 10:16 AM
golfmedik's Avatar
golfmedik
Thank you. With us being here in GA, you well know the type of 'slush' we get. I have been thinking about putting a splash guard of some sort on it to keep the ice and salt from directly hitting it. I really didn't want to do a complete enclosure like some have done due to getting a 100% duty cycle compressor and worrying about the heat build up. So yeah, I'll need something.
Old 07-31-2012, 04:44 PM
jasfaa's Avatar
jasfaa
jasfaa is offline
Great Idea. I have been looking for rubber covers for mine for months. I have seen them on work trucks, just didnt now where to get them. Thanks golfmedik
I've had a constant air leak since the system was installed and it was the air chuck every time. I've bought 3 different chucks(all made in Ch**a)
It fits REALLY WELL, so don't push it on all the way, or you will be prying to pull it off. No cold weather, so I don't how it will react as far as contracting. It is rubber so who knows.
Old 09-09-2013, 07:00 PM
DaveNTx's Avatar
DaveNTx
DaveNTx is offline
Hello,
I just bought the Viair 10007 kit and will follow your installation arrangement also. How many holes did you drill on the frame to mount the compressor bracket?
Thanx for any feedback.
Old 09-09-2013, 07:44 PM
golfmedik's Avatar
golfmedik
Originally Posted by DaveNTx
Hello,
I drilled 4 small holes if I recall correctly. Although I think one of them may have already been there. Can't remember, but I did use grade 8 bolts with Loctite and they are still tight.
Old 09-10-2013, 05:58 AM
DaveNTx's Avatar
DaveNTx
DaveNTx is offline
Thanks Monty, the compressor kit should arrive next week and I'll be collecting parts and pieces for the installation.
Old 09-29-2013, 09:08 AM
DaveNTx's Avatar
DaveNTx
DaveNTx is offline
Air tank pressure gauge light wiring
All wired into the 30 amp Upfitter #1 switch which controls the system. I left the 30 amp inline fuse from Firestone under the dash near where I joined the Upfitter as a safety.
Hi Monty,
OK - I've got the Viair tank & 450C compressor mounted under the truck (2013 F250, 6.2L) and am getting ready to hook up the wiring - did you connect the Viair tank pressure gauge light wire to the upfitter switch too?
Old 09-29-2013, 03:00 PM
golfmedik's Avatar
golfmedik
Hi Monty,
I never did hook up the gauge lights. However had planned to do it like you said. I have two gauges, one Viair gauge and one Firestone one. Was thinking about hooking the two together like that. To be honest, just hasn't taken the 5 minutes to do it.
  #28
Old 07-14-2014, 07:57 PM
BulletsForFingers's Avatar
BulletsForFingers
BulletsForFingers is offline
How did you mount your compressor to the boxed frame? I can't figure how you'd get nuts on the bolt since the frame is boxed.
Also, how is it holding up?
  #29
Old 07-15-2014, 02:04 PM
GHeTTo JOe's Avatar
GHeTTo JOe
GHeTTo JOe is offline
the kits i have seen have two brackets that are on either side of the frame and have bolts holding them together on the top and bottom of the frame.
  #30
Old 07-15-2014, 02:15 PM
BulletsForFingers
Got any pics of that? I get the brackets for the tank, but he's mounted that compressor right on the side of the frame.
Quick Reply: Viair system installed. Love it!
