flathead original gauge 12 volt conversion
I switched my truck over to 12 volt a while back and I am still having trouble getting the gas gauge and the temperature gauge to work. the oil pressure gauge works great. but i dont think its a problem with the gauges, i think its the way they are wired. does anyone know how to wire the temperature switch and the fuel sender for 12 volt negative ground?
Well, that's where I'm stumped. By lookin at the truck it looked 6 volt but it had some 12 volt parts like headlight bulbs. And it has a half way wired up new wiring harness. But it seems as tho someone converted it from original 6 volt to 12 and someone else half *** wired it back to 6 volt. So I'm not sure if those temp switches are 6 or 12 volt
http://www.vanpeltsales.com/FH_web/flathead_drawings_electrical.htm
Here is a picture that I took of the back of the gauge cluster. Provide 6v from a voltage regulator to the strapped side of the temp gauge (actually any of the strapped terminals will do) then the other terminal goes to the respective sensor for each gauge.
The gages require 6 volts, but the lightbulbs you just change over to 12 volt. I like to use the LM7806 integrated circuit voltage regulator. It takes up to 36 volt input and regulates to 6 volt output. Each regulator is good for 1 amp, so just use 1 per gage. Will not work for heater fan or elec wipers, those need higher amps. The LM7806 are small and you can hide them behind the gage panel. They should be mounted to a heat sink, a simple strip of metal or similar works great. Three wires: input, output and ground.
Just generically speaking, on any old car or truck with 6 volt, the ammeter works on either 6 or 12 volt, no need for any conversion except change the lightbulb to 12 volt. Mechanical temp or oil pressure gages do not need converting beyond the lightbulb.
The stock temp gauge reads temperature just like you are used to on every other car / truck. The six cylinders had a regular (for Ford) sending unit that varied resistance with temperature. Voltage is supplied by the gauge and the sending unit provides the ground. The hotter the sending unit its, the the lower the resistance and the hotter the gauge reads. The confusion is in the sending unit set up on the V8s since there is both a sending unit and a thermal switch. The driver's side head had the same sending unit the six had. The passenger side head had a thermal switch as a kind of safety back up. If the passenger side head got to boiling temperature the thermal switch closes and throws the gauge to reading full hot.
petemcl is correct, the double pole is in the driver's side head and the single is in the passenger head.
I also was wrong when I said the hotter the temperature, the lower the resistance. It is exactly opposite, the hotter the higher the resistance. The double pole thermal switch opens when it gets too hot, cutting off the ground entirely, which sends the gauge to full hot.
I really should post less when I am tired...
Try the following steps:
1 - First make sure you are getting 6V to the gauge.
2 - Second make sure the gauge still works by grounding the sending unit wire momentarily. The gauge should dive for cold when the wire is grounded. Don't do this for too long as you can send too much current through the gauge and damage it.
3 - Third, if the gauge works hook it directly to the sending unit (the single pole unit) and see if the gauge now works. If not you likely need a new sending unit.
4 - Fourth, if the gauge now works put the thermal switch (double pole unit) back in the middle of the circuit. If the gauge stops working you need a new thermal switch.
I hope this helps.
I hope this helps.
pineconeford
03-31-2013 10:20 AM
Goatjacket
08-12-2012 07:24 PM
lshort
13
04-07-2002 07:59 PM
