Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-22-2012, 08:10 AM
giants17068 giants17068 is offline
Garage is empty, add now
giants17068 is starting off with a positive reputation.
2007 Expy Limited 4wd low problem
My Expy will not shift into 4wd low. It will shift into 4auto and 4hi but not into 4wd low. Any advice would be appreciated thanks.
  #2 (permalink)
Old 05-23-2012, 06:13 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Vehicle stopped? Transmission in Neutral? Foot on brake?
Quote:
Shifting to/from 4L
1. Bring the vehicle to a stop.
2. Place the gearshift in N (Neutral).
3. Move the control to the desired position.
The message center will display “4X4 SHIFT IN PROGRESS” during the
shift. The RTT location in the message center will then display the
system mode selected.
If any of the above shift conditions are not met, the shift will not occur
and the RTT location in the message center will display the appropriate
information.
Note: Some noise may be heard as the system shifts or engages.
-- Chuck
  #3 (permalink)
Old 05-23-2012, 10:12 AM
Yes sorry I did not include enough details. I have shifted into/from 4low several times. The message center always walks you through it. However now when I try to shift into 4L the message center does not say to shift into neutral as it has in the past. Also you don't here the shift motor engaging.
Tags
2010, 4wd, explorer, ford, shift
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
