78 f150 won't start
78 f150 won't start
So,
I dropped my truck off at a local shop to have steps put on (they look and work great by the way) and they couldn't get it started. They quickly tested it and told me it had no spark. I had it towed home and tested it myself. I had spark through the MSD box and the coil (used the test procedure from MSD's website to ensure the box is still good). No spark at the plugs...must be the distributor. Replaced distributor. Good spark at plugs now, but still won't start...grrr. Checked fuel again. good to go 6psi to the holley 1650, fuel in the bowls, etc . It will crank several times strong, then does a slow crank, then several times strong again, but won't fire. Any ideas?
460, C6. Thanks!
460, C6. Thanks!
jamesh23
08-27-2016 11:53 PM
Scoop531
08-09-2015 01:00 PM
Beastie
23
01-26-2014 01:34 PM
My Clunker
08-03-2003 11:08 PM
