Replacing 2012 OEM sob with 10in sub with the OEM box in a 6.7l. What do I need?
I have a 2012 king ranch. I plan on replacing the oem sub with a 10inch sub. Yes I know I'll have to cut it a little... but other than that will it work? It's a 600 watt sub and plan on putting in a 1000 watt amp with it. I also have another sub that I plan to build a box for to put in behind the seat with it. Will this work with factory wiring or? And also. What wattage is the factory amp?
90F250351
02-09-2010 09:10 PM
bustedonce
05-15-2003 08:55 PM
1969Ford_360
05-13-2003 08:47 PM
