Off Road Lighting
heres the light bar.
Manufacturers of high quality Nerf Steps, Prerunners, Harley Bars, Light Bars, Replacement Front Bumpers, Rock Rails, Rear Runners, Tire Carriers & Truck Accessories
so your saying go with a dual relay setup? fords relay and then the relay that comes with the light?
just to be clear... the upfitter switches control relays. those relays are what accessories are connected to. the switches themselves can only handle enough current to power the relays. but it seems as if some of you are suggesting using different or additional relays from what i gather. not sure why tho
You could or you can use a bigger (correct amperage) relay and the switch and unhook the factory relay if desired to simplify and eliminate a fail point. When I redo mine this fall I will have four on a randy ellis bar on the bumper and two on my ladder rack. All lights will be on the same switch (it suits my purpose).You can modify the switches and relays to suit your purpose if you need additional amperage for lighting etc. as long as the wire and fuse sizing is correct
I would highly recommend going with Rigid Industries and one (or combination) of their LED light bars. I have two Dually D2s on my motorcycle and these are really nice bright lights that are virtually indestructible. My bike is dual sport that heads off road on a regular basis and these lights have performed flawlessly.
Admittedly, they are a little more expensive, but since they are LED, the power draw is minimal and it wouldn't be too difficult to wire them into the high beam circuit with a relay, or wire them to your upfitter switches. Rigid even has a specific light bar and mount to fit in the front bumper of our trucks between the tow hooks. Good Luck.
#29
In stock and ready to ship is the all new LED light bar kit for the 2011 & 2012 Ford F250/350. This kit comes with all the hardware needed for a no drill install. The light is also included. Utilizing existing bolt holes this kit will mount a 20" E-series light bar in the lower grill opening. Includes full color instructions.
#30
PITS !!!
that is Coo- WELL !!!! another option
Which is that ?
the M&R LED lightbar you have in your signature ?
Home - M & R Automotive
led light bar by "M&R" 24" 120W 40LED * 2 - YouTube
Which is that ?
