Squeaking, help!!!!
Old 05-05-2012, 03:35 PM
metal5486's Avatar
metal5486
metal5486 is offline
Cool Squeaking, help!!!!
I have a 1996 f150 351 4x4 e40d, shortbed. I've been hearing a sqeaking sound coming from underneath the truck while driving. its not a belt because it dosnt do it while in neutral while reving the motor. today i replaced the u joints and that didnt change a thing. it squeaks around 30 mph.it only squeaks when u have ur foot on the gas, as soon as you let off it stops. its not the breaks, those are new. and the front has new bearrings. im worried now that it is the transfer case.anyone have any ideas that can help.??!!!
Old 05-09-2012, 09:54 PM
nelsonc441's Avatar
nelsonc441
nelsonc441 is offline
does the squeak ring at a consistent wavelength to anything? if so, its drivetrain. if it just sounds like random racket, it could be suspension or frame mounts.
Old 05-10-2012, 01:56 PM
metal5486's Avatar
metal5486
ya it sounds like drivetrain to me, only makes the sound when im driving, like something rotating. just not sure what it is, the truck still drives fine. im going to change the t-case fluid this weekend
Old 05-10-2012, 02:29 PM
critterf1's Avatar
critterf1
critterf1 is offline
Have you checked the U-joints?
Old 05-11-2012, 05:13 AM
metal5486's Avatar
metal5486
they are brand new, i replaced them because i thought that was the problem
Old 04-14-2013, 10:50 PM
jtsim64's Avatar
jtsim64
jtsim64 is offline
I have the exact same problem with my 2007 ranger. Really interested in whether you solved the issue.
Old 04-18-2013, 01:28 PM
metal5486's Avatar
metal5486
turned out to be the stupid heat sheild that goes over the cat, a couple of the bolts rotted and broke so it was slapping around underneath the truck and making noises.
ChalmersP
12-03-2017 04:23 AM
jbabbler
10-28-2014 07:22 AM
Chris Williams
13
11-23-2013 02:03 PM
Duffy289hp
2004 - 2008 F150
05-21-2012 08:01 PM
Quick Reply: Squeaking, help!!!!
