If you have oil blowing out of the injector near the head then you have bad oring.
The injectors that don't have oil coming out of the spout are dead. You need to ohm the solenoid. If they have no more than 5 ohms the solenoid is good and you have to replace/rebuild the injector. If the solenoid is bad you can but just it.
ok pulled the injectors that were not spitting out oil and ohmed them they are right about 3.5 ohms. is that whats its supposed to be or does it need to be closer to 5 ohms.
Pull the solenoid off the injector and youl will see a square plate. See if you can get a .002 feeler gauge under that plate I'm willing to bet you can't.
also i do not have the $1300 to get the injectors rebuilt but my local wreaking yard has some used ones for $50 a piece. can i just replace the ones that are bad,or will that be bad for the truck
