Skyjacker SKYF9461KS-N Lift on 2009 + F-150
Well just so everyone knows, you CANNOT use the stock 17x7.5 XLT rims with the Skyjacker lift even with spacers. Unfortunately my spacer idea didn't work. It wasn't the vertical spacing that was the issue like I had originally thought but rather the horizontal clearance:
I went ahead and purchased 20" rims with some 35x12.5R20 tires. Should be ready to go by Saturday. More pics to come.
If you're going with skyjacker yes.
I asked the suspension guy what his honest opinion of the lift was....his exact words, "Honestly, this is the best designed lift i've seen. Between the rear leafs and the front design you can't beat it."
He asked how much I paid for it and couldn't believe I got it for the same price as a block lift.
If you think about it though, the very fact that the knuckle is big enough to require 20s compared to all the other lifts tells me it's beefier than the other lifts as well.
Testing out the new suspension...had to ensure it worked.
Absolutely zero frame twist, which I was please about after having a 1997 F-350 that would twist so bad the tailgate would pop and be unopenable
About 1/4" between the tire and the shock. Perfect offset/tire combination.
No rubbing here...the 35x12.5's on the 20x9 rims w/+25mm offset tuck under the wheel-well nicely
