getting rid of bad gas
Received 3,108 Likes
on
i went to move the 2000 yesterday and it will not start because the gas went bad .
it has been sitting about 6 months, since it did not snow this past winter.
how do i go about cleaning the fuel system?
i was thinking suck the gas tank empty with an electric fuel pump, and blowing out the lines with air. does this sound rite?
How much fuel we talkin' about still in the tanks?
If you do replace it all with known good gas I'd add a bottle or two of Techtron and let it run through the system. I'm thinking after a few minutes of running the bad fuel should be burned off and no longer a problem. I could be mistaken in this though especially if it refuses to start altogether at the moment.
on
are you sure you don't have other contributing factors to not running....no spark...blown fuse ...etc??
If you still need to empty the tank then either drop the tank or remove the bed , remove the pump and drain it that way
on
on
well, it's alive again. 7 gallons of stale gas out of the tank, and 3 hours to purge the lines. it finally started. i put 1 half pint of seafoam in the 1 gallon can the fuel pump is in, and let it run for 3 minutes to circulate the seafoam. it is now sitting to let the seafoam do it's magic.
on
on
if i had not had the service truck here, it would have been used as weed/bug killer around the property.
i am not to concerned with what the epa ***** say.
it came out of the ground, and people have been using petroleum products as insecticides with excellent success for many many years until the tree huggers decided it was bad and we should use man made carcinogens instead.
most of the time the crap they tree huggers want us to use is 100 times more dangerous than the natural products used for centuries before
paolca
2004 - 2008 F150
06-20-2015 02:31 PM
Aviee
13
06-28-2012 12:04 PM
SAR Ranger
12-27-2002 03:52 PM
