various parts for 53-56 trucks
Category: Accessories
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): CRX & pre '92 Civic
Item Condition: IL
I'm not comfortable selling it in that condition so I've decided to scrap the frame after pulling any useful parts off it. So, I will be removing the front axle and steering gear. I should be able to find a hot-rodder interested in that. The front cross member and tranny cross member look to be good. I'll be removing the rear axle as well. Let me know if there are any frame parts you need before I cut it up and take it to the scrap yard.
Kevin, I've done some research and found that the diameter of the input shaft{the one at the front of trans) is 1 3/8" for the trucks and 1 1/8" for the cars. Could you find your calipers and verify which it is? Also what is the length from the front tip of the input shaft to where it goes in the trans case? Thanks
Here's the tailshaft (~1 1/8")
I forgot you wanted me to measure the length. I'll do that over the weekend.
Thanks!
The perspective is a little off on this photo. Just shows where I measured from
Let me know if you have any other questions.
