ZF 5 speed swap ability.
"Yes, it is possible to elongate two bolt holes in the 460 trans to get it to fit the 7.3 but because of the shape of the flange it is not possible to get a 7.3 trans to fit a 460."
Could you explain that a little more please? What is it that makes the 460 able to fit the 7.3 but not the other way? I understand that there's a difference in the bolt pattern. (must be pretty slight difference) thanks
ZF transmissions were only used for F250/350 trucks. a M5R2 would NEVER hold up to the power of the 460/ 7.3
So out on the highway he's gonna be cranking some relatively high rpm's (2,500-3,100 ish) and that'll drag the MPG down some.
But on the other hand, it's strong, reliable and cheap the rebuild.
With a mildly built 460 .30 over carburated motor. (Haven't chosen the valve train yet) Fuel mileage is already not a consideration. Reliability is. What is the maximum RPM range we should shoot for without damaging the motor? This truck is being put together for small town prowling and weekend mud holes. If it sees any highway it'll be on a trailer. I just want to be sure we are putting together a good combination. Any advice we can get is greatly appreciated. Never done this before.
Received 3,108 Likes
on
the mazda transmissions were used on the small gas engines and will not fit on a diesel.
#28
#29
on
