351 W timing chain
351 W timing chain
Hoping the expertise of this groups can give me some advice...long story shot: 1988 F250 4WD auto, allegedly broken or jumped timing chain. Haven't turned it over for fear of damage. Will I find broken/bent valves? Other damage?
This nice big truck will replace (finally) my good ol' 1960 F250 while it's getting kingpins.
Thanks everybody...all comments welcome.
351 W timing chain
there shouldnt be any damage from it slipping, just pull it apart and replace it and go on your merry way. I have had several jump with no problems, it might just be a bad wire somewhere tho, I had a 1982 van that we thought te timing chain had gone in but it was a hot wire going to the ignition grounding out.
351 W timing chain
Hi,
Before ripping the timing chain out I would find out actually what was wrong causing the no start. If you have Compression, Spark, and Fuel you should be getting something, so I would begin checking there.
Then I would check to make sure that the distributor is turning and then, check to see if the engine is in time or not.
Also I would think with a stock engine even if the chain broke (although I never saw a broken chain just slipped or the plastic broken) you would not have any valve to piston contact.
Good luck,
Tom
Good luck,
Tom
