Overdrive transmission question
Old 10-30-2013, 04:51 PM
dcagnolatti's Avatar
dcagnolatti
dcagnolatti is offline
So my '59 is at the transmission shop waiting on a complete rebuild. When I bought it, I was told it was equipped with an overdrive transmission, but the cable had not been hooked up. I asked the transmission shop to see if they could get the overdrive working. It would really improve my gas mileage.
Has anyone else been through this before? Have any insights, do's and don'ts, words of wisdom about the overdrive feature on these 3 speeds?
Old 10-30-2013, 07:29 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
I hope your shop has someone with experience with these overdrives units
( read one of us old guys ). Besides the mechanical part there is an electrical circuit with a relay, kickdown switch, solenoid and governor. Many of these parts are getting hard to find and are expensive when you do. When working properly they are great, I've used them in several passenger cars and have one in my F100..
Old 11-01-2013, 11:54 PM
dangus's Avatar
dangus
dangus is offline
You could get away without some of the electrical stuff... it's designed to kick down into normal drive when you floor the gas. But it wouldn't be too hard to adapt a common relay and a momentary contact floor switch (starter? horn?) if you don't have the originals. If you need the lockout cable assembly, those may still be available from Ford truck specialists. (I bought one around 1990, although the plastic handle looked like a different type of plastic than would have been used originally.) I only took one test drive with the O/D transmission, since something went wrong when I reassembled it and the cases didn't seal properly. That particular transmission wasn't from a Ford, and has since gone to the scrapyard. (I did save the solenoid and governor.) I scored an allegedly Ford 3 speed/OD from a swap meet, but haven't tested it out yet.
For a working truck, it might be wiser to install a truck 4-speed (with the granny 1st gear), or spend the bucks for a modified bellhousing to fit a modern overdrive transmission. I've encountered a couple of hills that couldn't be climbed with a loaded truck in 1st gear with a light-duty 3-speed. One hill could be avoided; the other I backed up and took a run at.
Old 11-02-2013, 12:08 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Recent discussion with some links to parts etc. OD ratio was .70 or .72, allowing a shorter rear axle such as 3.89 or 4.11 etc or even 4.89s.
https://www.ford-trucks.com/forums/1...a-cruiser.html
John with beastly 302
15
03-21-2022 11:31 PM
Shane Carruth
02-23-2015 12:33 PM
erinaldi
03-30-2008 02:00 AM
F250Rob
34
10-27-2006 07:02 PM
jmooremtb
06-02-2004 11:37 PM
Quick Reply: Overdrive transmission question
