1959 F-100 4x4 Arizona Beauty
#46
on
You realize now of course that you've but in the Toyota Conversion, that you No Longer have a Working Horn. It has no way to connect to your Horn Button on your Steering Wheel as you no longer have a way to access the Hollow section of the Steering Wheel Shaft.
If you figure some other way of connecting it up, other than placing a separate Horn Button some where else, I'd be interested.
#47
I got the engine running good finally... I resorted to changing out the dizzy for the one on my spare engine and back to points; runs great!
test drive this week!
#48
I went for the first drive ever today for a bout 40mins and had a great time. I've never driven a manual transmission before so learning on the on the clarke 5 speed was interesting. Made horrible noises, ran over a few things, bounced around, killed it a couple times and left some marks in the driveway. But she runs, steers and stops great! very happy with the Y-Block It was hard to kill when I started in 3rd or 4th gear lol.
Here's some pictures of the radiator/mounts
http://desmond.imageshack.us/Himg696...pg&res=landing
The exhaust, my buddy let me have his old setup off his 67 fairline
Interior or lack-of so far, I got a steering center
The doghouse and my current mess
#50
I believe the steering box is from a 1983 toyota pickup with power steering.
So the big 60 mile drive home went good, got run off the road by two truckers, stalled in a police scene one lane bypass route. It was a good time lol!
Anyways, it runs great, starts easy and the transmission shifts fine. It has a top speed of 55-60 on the highway but I can live with that.
Cool kids parking at work
After I got it home I drove it to work and discovered that I forgot to tighten lugnuts on one side of the truck. I ruined two rims and 16 lugnuts I spent the day at the junkyards looking for new rims and got the tires remounted. I painted the rims almond and slapped them on. The previous owner also used a wrong leaf spring retainer which caused the U bolts to have 3” of separation at the top and 5.5” at the bottom. So I cut, bent and welded a new spacer out of some 3/8 and went to a local carshow.
Here it is parked next to a company car lol!
Today I took my girlfriend to the movies and went out to eat.
Dropped her off at a nice historic home she’s dog sitting at, couldn’t resist taking a picture.
So it is running great, no smoke, lots of power. But it is throwing clean oil out of the exhaust and it gets all over the bed and drips down from the mufflers.
#52
Well, I had a 312 ECZ-6015A with ECZ main caps lying around so I yanked the 292 put a new seal on the oil pan, cleaned the pickup and put it in it's place.
Lots of power and easy starting now, had no clue how worn the other engine was until I put this one in.
When I pulled it I found out that the 292 had some more epoxied cracks on the outside of the block then I expected.
Nice to have a forklift!
I don't normally wear my pants "gangsta" but in my excitement I ripped them and got too lazy to pull them back up
#53
I still need to find a seat and fabricate front shock mounts, expect to see that soon and the main seal on the 312 leaks so I have to replace that.
Here's a little video I took. Yes I stalled, 4th is too high of a gear to get out of the little mud puddle, then came a vigorous clean up.
http://www.youtube.com/watch?v=hw2Ut...1&feature=plcp
I wanted to get rid of the ugly gauge pod the previous owner had setup so I designed/made my own on the waterjet, I think I have $1.66 into this.
The DXF it came from, I threw in two switches for future mods.
I re-used 3 out of the 5 aftermarket gauges the truck came with; Oil psi, water temp and fuel level. I still need to finish up the dash, the only working things are the turn signal lights, gen and low oil lol.
Anyways, I wired up the gauges all nice with a 12 pin molex plug.
After dropping $3k to restart the school semester I had some really good news! Discount tire called me and said the BFG commercial T/A's on the tire are part of a bad batch so they will replace them for free!
For a little cash thrown in they said they would have no problem if I step up to some 255/86/16 km2's
So new rubbers soon!
#56
#57
#59
Excellent choice on the tires! To me the 255 was the best thing to ever happen to 16" tires. For people who like the narrow look and the 33" diameter of those tires, but have 15" stock wheels, check out the 33 x 9.50 x 15 size. Same tire with a smaller hole in the middle. Interesting to see it parked alongside the 6x6. Two clark 5 speeds in one parking lot. That's one oddball shift pattern! Keep up the good work and don't start out in 3rd or 4th gear. I can smell your clutch smoking from here!
#60
