the official OBS diesel off topic thread
Efuel is getting close. Just need a couple fittings to complete the top end mods (just going to use the stock lines and banjo bolt for now), then a bracket for the pump and filters, plumb that and some wiring. I was going to get a rebilled kit but he's a little busy right now and I found a good deal on an SD pump and bracket; so I started compiling my own kit. But I will say that I've seen what comes in a rebilled kit and what he told me he charges is a steal; I'm not sure how he makes money on them.
Anyhow, I found a I 5/16" Hose Barb x 9/16"-18 Male Adjustable O-Ring Boss that will work perfectly for the return off the regulator. Every build I've seen so far used a -6 AN fitting adapted to a 5/16" Hose Barb. This one goes straight to hose barb. It's Brennan Industries 4601-05-06-NWO-FG. Hope this helps someone someday.
Anyhow, I found a I 5/16" Hose Barb x 9/16"-18 Male Adjustable O-Ring Boss that will work perfectly for the return off the regulator. Every build I've seen so far used a -6 AN fitting adapted to a 5/16" Hose Barb. This one goes straight to hose barb. It's Brennan Industries 4601-05-06-NWO-FG. Hope this helped someone someday.
Rre /Newport bound.
Does anyone make metal interior door handles for our trucks? I broke my stock one off, put one on from O Reillys and it broke off a month later... The guy behind the counter said his son had a dump truck that wouldn't keep a plastic handle for very long so he put metal ones on. Ive been looking over the internet and cant find squat
Received 3,108 Likes
on
doorman 77178M driver side, $11.76 from amazon:
https://www.amazon.com/Dorman-77178M...or+door+handle
77177M passenger side, $11.81 from amazon:
https://www.amazon.com/Dorman-77177M...ype=automotive
no M is the plastic handle, M is a metal handle.
fits 87 to 97 pickups.
on
on
1 Post
