the official OBS diesel off topic thread
Byron, 20-22 psi is doing real well for non Cali and stock sticks. I'm not sure I could push that with chip and my ol slush box. Then again, I'm not sure how long my uppies have been blown apart. Oh and my Buckeyes keep Rollin!
My day was supposed to be filled doing 2 brake jobs and a window reg on my DD so I can put my truck away for the winter. Mother Nature, however, had a different plan. We had to get the plow trucks ready and will most likely have to head out early. Calling for 4-6". Yep. Not ready for this crap. Lol
Byron,those numbers are about norm with my auto meters.,
Well,I got the stupid hpop bolt that was pulled out repaired and clifford all buttoned up.drove him last night for the first time. Fresh oil change and new fully functional brake boster.man I have to say that the t-500 perked the ol turd up and I can dependably stop for the first time.
I'm thinking about talking with a local dyno shop about getting some baseline numbers as a refrence incase I get to do any more serious mods...should I ,should I ? ??????
And I worked on two other psd trucks this weekend with a third yet to get started on...and my dad dropped his suzuki sidekick off for me to rebuild the trans in....I'm SO buried!
And 3-5" snow tonight a week BEFORE thanksgiving....sure thanks for global warming...lol
I think for a basically stock engine its about at the limit other than an ic which on a dyno I don't think would matter any. I would hope for 250 at the tires.opinions?
CORRECTION....25-30 cents MORE than UL gas. Sorry guys! I was typing too fast. Thanks for the info Todd and Aaron and someone else...dang I forget and can't check right now! JP? Mike? LOL I was wondering if boost was low, but seems good for stock sticks. That'll be the next change here pretty soon! Heh heh....
Man for you guys that have to plow, that SUCKS! I am about to be in the frozen tundra myself shortly. No more 70* weather every day for me. Ah well, would rather be on a horse in cold weather than staying warm with crowds and aholes I guess... Texas gets more freezing rain than snow, which I hate more than anything, but the Hill Country is mild for the most part.
Definitely Dyno! Then you can reburn your tunes if they need adjusted. I'll be hitting the dyno as soon as all the major engine work is done. I'll be turning the base 445 into a 450.14CI after I bore up. Not sure of the gain's I'll get from that base engine, because I'll be running stage 2's and a T500 installed at the same time(if all goes well!)
Weather was bearable here. Only got 2-3 inches and didn't stick to the roads (that's the best kind)
Gas is $2.89 and diesel finally dropped to $3.62. Yup, 73 cents difference. I saw at a couple filling stations in Evansville gas $2.99 and diesel $3.99
It doesn't help my truck cant seem to get over 15 mpg recently. The Olds should get 23ish. Hopefully better with the new pump
