the official OBS diesel off topic thread
When I do the hinge pins, I use a die grinder with a cut off wheel to grind the head off the pin. The use a punch to drive the pin down and out. I you do one hinge at a time, you can get the new bushings in, and get the pin back in, with out removing the door. This way you usually don't have to mess with re-alining the hinges to get the body lines correct.
I need to get the pins/bushings - anyone got a source on that?
Well, I guess its my turn on the bad luck merry-go-round. On top of the dead mouse in the seat of my 97 on Monday, the AC compressor seized up on my 96 last night. It must have sat too long I guess. I unplugged it for now.
I need to do the door hinges as well, but that's low priority right now. What is the approximate cost the fix?
Phil..I win.
Installed my t500 last night and pulled the threads out of the timing cover on the pass side bolt.it never even got snug.threaded in by hand,drew up with 1/4" ratchet just to get flush with timing cover.got the torque wrench and went to torque things and it just spun..pulled pump and the threads came with the bolt...heli coil install tonight..
I got mine from O Reillys. Cant remember if it was $8 or $12 a pin (x2 of course). Quite a bit more expensive than I was hoping.
Finally got the fuel pressure gauge on the Cutlass yesterday. It was putting out around 15 psi (internet says should be 34-36) but he said his gauge has a tendency to leak. Bought a fuel pressure regulator for it anyways. $50 shot in the a$$. Didn't do a bit of good.
Because you need a pump dingleberry...cough it up chump lol
on
1 Post
Phil..I win.
