Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-18-2012, 06:54 PM
Zaxbig89f250 Zaxbig89f250 is offline
Garage is empty, add now
Zaxbig89f250 is starting off with a positive reputation.
Veg oil swap
I have a 89 7.3 idi it has two tanks I was told if I run 100% filtered oil in one tank and 100% diesel in the rear tank crank and shutdown on diesel and run on veg oil during operation it would work fine is this true also can you run hydraulic oil or anything other than veg oil thanks for help
  #2 (permalink)
Old 04-18-2012, 06:59 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Running WVO (waste veggie oil) Requires heating the WVO BEFORE using it and starting and stopping on reg diesel. Using any waste oil (motor, or trans) is not a good idea. Take a look at a Blackstone oil analysis to see just what nasty chemicals and metals are in it...............
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 04-18-2012, 07:02 PM
So if it is warm you still have to heat if so can you buy tank heaters and also if you mix do you have to heat
  #4 (permalink)
Old 04-18-2012, 07:05 PM
1935 Ford pickup
They will seperate if mixed. Try here for more info: WVO Diesel Conversion | SVO Grease Conversion | Ford Vegistroke Powerstroke | Biodiesel Conversion
You can also do a search of this forum........
__________________
  #5 (permalink)
Old 04-26-2012, 11:49 AM
linus72's Avatar
linus72 linus72 is offline
1990 Ford F-250
My Garage
linus72 is starting off with a positive reputation.
first...I'm no expert, and have only been running variations of many fuels for like a month, and have had some issues along the way...my two cents follows-
first I kinda disagree with fabmandelux's statement that WVO and diesel will separate...I take it you mean they will separate if left sitting still for a period of time?
I did my own test and used a 50/50 mix of WVO/diesel and let it sit for 3 days in a glass at room temp and I could notice some separation...
But, in a truck that's turning corners and going up and down hills I doubt very seriously it would separate or am I wrong?
second, my mistake was in mixing WMO and WVO, never let them mix because it forms into little black globules and is currently clogging my filters...so get all the motor oil out of the tanks before running WVO...
I never actually started my truck cold on 100% WVO, but am currently using a 50/50 mix and it starts cold just fine at about a 50-60 degree temp in the morning
I am putting like 1000miles a week on this truck and have had zero problems running the WVO whether the truck was cold or hot.
I have noticed that when the truck is running on 100% WVO it is much smoother and quieter and seems to have more power...but it's definitely smoother and not alot of knocking like with reg diesel.
my only suggestion besides fabricating a WVO heater would be to filter it as best as possible.
I plan to fabricate a pre-heater using the coolant lines.
  #6 (permalink)
Old 05-07-2012, 09:38 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud of
What about before ya start it up in the AM? The fuel pick-up is in the VERY bottom of the tank, so anything that settled out is first thing to be sucked out at start-up.
Truck will likely start and run 'fine' on 100% WVO with warm enough ambient temps. However, the lack of complete combustion from trying to spray this goo through the injectors will slowly cause coking/carbon build-up that will cause major problems. Also, during warm-up all diesels have alot of blowby. Your diesel engine oil has disperants, etc in it to help keep diesel contamination from being a problem - but WVO in the crankcase rapidly polymerizes and prevents adequate lubrication. I have seen many 'blenders' stop after getting a couple of nasty UOA's back. Between the coking in ringland scoring the cylinder walls and poor lubrication of parts - the wear levels in engines that are 'blending' WVO tend to be very high.
That said, it is a slow death and there is no cheap recovery. Once it starts to 'run bad', the damage is done. No worries though, there have been LOTS of people who have made these mistakes and we have learned from them!
I have over 250k miles running WVO and have yet to have the first fuel-related problem. I average burning WVO about 75% of the miles I drive and have been as far as 10,000 miles on a single tank of diesel. Yes, I spent a few $$ setting my truck up - but I got that back so long ago the cost is irrelevant. My advice is do it right and reap the benefits of nearly-free fuel without all the problems (like you've already had...)
If not, Please Post Pics of the Carnage!! We love that stuff.
__________________
2000 Excursion, Limited, 4x4, Frybrid/V3 VO system, BTS trans, Gearhead tunes, Mahle pistons, 910 springs, chromo pushrods, headstuds, AC codes, T4/S366, carpet delete and other stuff. Also, 2001 F350 CC flatbed - currently w/no engine...
Quote:
Originally Posted by SpringerPop View Post
There are none so blind as they who WILL not see, nor so deaf as they that WILL not hear. Pop-Psalm 4:44
  #7 (permalink)
Old 05-07-2012, 10:16 PM
Christof13T's Avatar
Christof13T Christof13T is offline
The Dr. will see you now.
2000 Ford F-350
My Garage
Christof13T is a splendid one to beholdChristof13T is a splendid one to beholdChristof13T is a splendid one to beholdChristof13T is a splendid one to beholdChristof13T is a splendid one to beholdChristof13T is a splendid one to behold
christof13t
you right there sky..
not much better than engine guts ****!
and the more i read about it... i cant see why everyone isnt running wvo... will be the absolute first modification i make to my truck when i get her home... so anxious. and i just broke that fingernail biting thing too!
she is awaiting a front axle seal job (4x4) and she should be good to go. hoping the tires hold up for a while... shes been sitting about 2 yrs...
anything in particular i should bolo for on a 7.3ps that has sat for so long?
xtof
Tags
64, bronco, conversion, diesal, diesel, engine, ford, kit, oil, replacement, swap, tank, veg, vegetable, vermont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
