Dad's ZF5 Swap
#586
The '87-'91 taillights have a clear section that wraps around the whole bottom of the lens, not just a little window facing rearward.
Go look on LMC or somewhere to see the difference.
#587
I don't know if my Ebay purchase history goes back far enough to find them...
I have not done the 1157's and an electronic flasher....yet.
#588
I was thinking that for this application firing everything to the rear would be best. I'm going to have to look up the lumens on an 1156 as I've found and LED replacement that puts out 88 lumens but don't know how much brighter that is.
#589
My truck IS an '87, it came with the later lenses.
These are the ones in my purchase history.
Car 1156 7506 White 24 LED Bulb Turn Signal Lamp 12V | eBay
And, I was wrong, it says "18 out the end and 6 mounted radially".
#590
Ahhhh, I forgot that your's is an '87. So, you don't know how much better those are vs the earlier ones.
As for the LED's, I may go with those if you say they are brighter. I'm confused with all the ones that Amazon has available, but there are so many duplicates it is hard to make comparisons. Thanks for the info.
#591
Ok, it is about time to finish this thread up. Some time ago I think I said I needed to do three things to finish up. Here they are and here's the status:[LIST=1][*]RP Synchromax: I ran O'Reilly's ATF in the tranny for ~1500 miles and now I'm going to put Royal Purple's Synchromax in with the hope that it'll quiet the tranny, protect the synchros, improve shifting, and maybe even help on the MPG.
#592
#594
#595
I know, right? I'd been looking for a couple years and had only been finding $500+ units. By inspection plate, do you mean the piece between the engine and trans? I have that, actually I went back and dropped another $150 and got the clutch, flywheel, starter, driveline, floor cover plate, hydraulics, crossmember...etc. So I'd hope I have what I need.
#597
Ok, for the record I put the RP Synchromax in and I think it is the way to go. It reduced the noise of the transmission quite a bit and the shifting is somewhat better. So, I would recommend it to all ZF5 users, although it is pricey. And, smelly. But, it seems to work.
And, with that I've gotten everything I'm going to do re the tranny swap done. So, I'll say its a wrap, but will be happy to respond to anyone that comes along asking questions about swapping a ZF5 onto a 351M/400.
#599
Ok then, just a brief summary. I have about 2000 miles on the ZF with no problems whatsoever with the spacer and anything associated with it. No vibrations even though I've spun it to 5K numerous times. No change in the starter's sound, and I did pull it at one point and there was no extra wear on the teeth of the starter nor flywheel. And the 11" clutch is handling things very well.
It was a lot of work, but I'm happy with the results. The reduced engine noise while cruising, the increase gas mileage, and the ability to cruise at any speed w/o spinning the engine rapidly make it worth the effort. And, I've always wanted a manual tranny in my truck!
#600
