Random measurements needed - standard cab, long bed.
Hey guys - I'm doing a bit more random thinking on the possibility of a supercab bronco & I need a couple random measurements off a standard cab, long bed (non SCS) if someone has time. I don't have one around anymore so I can't measure.
A = if you drew a vertical line down from the back of the door jamb to the ground & then measured from the centerline of the rear wheel to this line.
B = from the line at the back of the door to the back of the body.
C = from the line of the back of the door to the centerline of the front wheel.
*This should be the same as any of the trucks I pictured below so I will also be measuring on my stuff to confirm.
What I'm looking for is pretty much something like this:
Thanks!
Thanks!
PL Allcritnohit
07-09-2018 05:19 PM
clintonvillian
01-29-2018 04:53 AM
xirxious
04-25-2012 02:56 PM
