New Guy - 1956 F250 Going from 38 yrs in Barn - Weekly Driver
Welcome to the 48-56 forum....that's a great find. A lot of guys with F250's want to keep the 8 lug setup...so you could find a Dana 60 from a newer F250. That 9" from a Bronco might be too narrow....do a search on rear end swaps. There are a couple of links and threads that have the full run-down on width and the best years. If you go with a Dana 60, you could probably snag the newer one piece wheels at the same time.
Dan
Dan
Where are you guys getting period correct white wall tires? I have 4 16" wheels and 2 17s all factory ford looking. Did these have caps on them? If so I'll be looking for a set of moons. I tried a set I had for 15s and clearly the bossing on the rim is different for the 16". I know the few Broncos had from Ford with 16s did not come with covers.
Period correct whitewalls? Just to be sure you know these trucks did not come with white walls as an option. Many guys have them on now though.
I think the F350's and up had the widow makers.
I put a 1968 DANA 60 with 3:73 gears in mine years ago, alot better than the rockwell rear that was in it originally, just rebuilt brakes, all parts are availible although I had to go with 2 1/8" x 12" drums could not find 2"x 12" which came with the 1955 F250. If I had to do it all over again I would have left my truck original. Have fun!
I doubt you will find good used 3/4 ton hubcaps. However, if you really want them, Dennis Carpenter has reproduction caps for sale, part number 2J-1130-A .
If I'm not mistaken, the 56s had a Dana 60. I believe it was the F350s that had the Rockwell or Timken (banjo).
PDX, it's possible that you could just re-gear your stock rearend. Not sure what the axle spline count is; most likely you would need a new carrier if you went to a higher gear ratio.
#28
I believe the change to Dana 60s came in '56. It's a split housing, correct?
A good read for you: (scroll down to 1953, 'tis why many still refer to the original split housing axles in 3/4 ton Fords of the era as "Timkens")
http://www.meritor.com/ourcompany/history/default.aspx
#29
Our History
Our History
1953-1955 F250
many think its ok to put a chevy in a ford
#30
