HIO Silver's Lo-Buck Bumpside Build
#1367
on
Thttps://www.ford-trucks.com/forums/1389504-hood-lock-home-made.html?highlight=hood+lock+home+made
this might be the same as above..
Being simple, and living without expectations, (at least not grand ones), I just went to the search window at the top of the page, and typed in Hood Lock, Home Made... and clicked on search.. wallah! or Viola, however you spell it.... good luck, and I bet you can build it in an hour, and the time to make a trip to WalMart for the lock..
Baja
Baja
#1368
Good day Mr. Silver,
I'm going to build one of your derusting contraptions. A little more heavy duty, I'll take pics as I go.
My question is this, I have plans to drop the spindles in, but I dont believe I've seen or read where you did that. Will the molecular spliting derusting process damage the spindle, where the bearings and rotor attach?
#1370
#1371
#1374
#1375
on
Question(s) for you HIO...
1) How difficult was the E-street EFI to set up?
2) How well does it work?
I'm considering it for my 351W build because I want my engine to be completely "turn-key". It's not that I don't like working on carbs, I just don't think I'll always have time for it (but I always want to be able to drive my ride!).
#1376
1. Super easy. The only issue I had was the Bluetooth addresses weren't paired and all that needed to be done was to program the correct numbers. Otherwise, plug and play!
Just a note on the throttle body, the fuel system is set up for a GM where the fuel inlet and fuel line from the tank is on the passenger side. You can swap positions since Ford's fuel line is on the driver side.
2. Runs great. I just cycle the ignition twice to prime the fuel pressure and she roars life.... cold start, driveability, and restarts are excellent. Combined with the five-speed the LBB is up to 18 mpg.
#1377
on
I've seen some comments on the tablet having poor battery life or not working correctly. Any comments on that?
Also, do you have any comments on the whole tech-side of things? Possibly a software update or something of that nature that caused you to have any down-time with your EFI system?
I'm just thinking back to Windows XP... it was the greatest system ever... until Microsoft stopped all support/tech systems for it. Wondering if this E-Street EFI will be the same way (long or short term solution?)
#1379
That's fantastic news. 18 mpg is fairly high on these old rigs.
Edelbrock's site provides for software updates. The tablet comes with cables and you just hook up, log in, and click away.
Yeah, the tablet's battery life could be better but the system comes with a cigarette... erra.. "power port" plug plus a suction cup bracket for the windshield. While the tablet is a neat interface, it is not required while operating the vehicle although it does provide useful information such as RPM, battery voltage, fan on/off indicators, and coolant temperature. The ECU does not rely on the tablet...the tablet is simply the interface to the ECU. Just like your computer monitor and the CPU... Any changes changes you would like to customize like the fan on/off temps goes through the tablet..... The tablet also 'saves" your money because of money you don't have to spend for gauges. The only additional gauge you would need is for oil pressure. That's it.
I chose the Edelbrock system because they're unlikely to go out of business or be taken over like Holley just did with MSD. They're website is cool and current as is their tech support in terms of reliability and accessibility. I have met Vic and Cammie Edelbrock (Coronado Speedfest) and their name is their brand and heritage and believe they are, and will continue to be, a stalwart of the automotive aftermarket.
#1380
on
On an FE, anything better than 15 mpg is fantastic in my book.
