HIO Silver's Lo-Buck Bumpside Build
#46
Here's another, short term option. The previous owner of my '71 had put a T170FS out of a mid 80's F-Series in the '71. It bolted right up to the FE bellhousing and provides 3 forward gears and a 4th overdrive. Granted it's no heavy-weight, but if you're just looking for an OD transmission to use for a daily driver, you might give it a look-see.
#47
#49
A Modicum of Success - Rebuilt Calipers!
The calipers came out of the vat looking good. Shot it with Rustoleum silver engine paint, a light hone, and rebuilt them with a new seal and boot.
Installing the square cut seal with no problem. However, lubing the piston and boot, and then encouraging the lower lip of the boot to seat required mucho patience. It was like try to catch a greased pig. The factory manual says to use a non-metallic tool to to push the lip down into the groove... I used the backside of a plastic knife (the dull side of course !) and seated her home.
Back into the parts bin it goes until installation day... ooh, still need to order brake pads. Any suggestions?
On deck is the crusty master cylinder.... it's almost done cooking in the vat. Here is what I started with.
Cost from the JY: $10
Rebuild kit from NPD: $24.95
#52
I've learned patience by being a fisherman.... Plus, my engineering professor once said, "Treat every piece like a work of art and remember, Rome wasn't built in a day."
#53
#54
https://www.ford-trucks.com/forums/9...g-upgrade.html
3G_Alternator
3G Alternator TECH [Archive] - FSB Forums
#55
Ease of installation? Mine has a set of older stainless long tube headers on it i recently did a starter and i think it'd be a bitch to get them in there as in having to lift the engine - but you got them in there without all that how much were they- i'm curious i don't need to replace yet but -Mines a 360 which is essentially the same motor -
#56
The ceramic coated Sandersons were <gulp> $525. Plain steel is around $375 IIRC.
#57
on
#59
It's here! E-Street EFI !!!
Some of you may know that I have had little time to spend on my project due to a house remodel so I've been gathering parts where and when I can. For Christmas, I figured on taking profits on some stocks (it's "play money") so I treated my 'low buck project' to an EFI system.
After five months being backordered and on a waiting list... it finally arrived in the big brown truck! Aint it purty?:
