Looking for Tuned 6.0's that have not been studded
I'm just curious of how many people are out there with Tuned trucks that have not upgraded their Studs. How long have you been running with a tune? And what has your repair experiences been since you tuned the truck?
Thinking about tuning the truck with my tax refund. SCT with Matt's SRL from Gearhead. I have not upgraded my studs and I really have no reason I need to tune it...I just want to.
What are your thoughts? Please Chime in!
ive heard that you want watch how hot the air is going into the turbo so you dont cause any problems once you tune the engine. its just a warning as to not cause to much damage to the turbo.
05 SCT Eric ID mild street tunes.
Just driven around town and highway towing 4 wheeler and bass boat.
My purpose was to have a little fun and make the truck more enjoyable, but nothing extreme = 500 Hp racing or striping.
It lasted about 35K miles, not bad all things considered.
went from ~65K in 2006 to 120K last month.
I'm now where you'll be so plan accordingly as in my opinion it's inevitable and unavoidable.
Sooo here's what I'm doing now that i have to:
ARP Studs
OEM Gaskets
Warren Diesel 155 Stock Nozzels
FICM Herc Tune
I.D. Extreme Street Tune
Rear fuel hose.
new serp belt & tensioner
Possibly Snow Meth Kit (still in box)
Vent CCV to Atmos.
Dummy plugs
Banjo Bolts
Stand Pipes
What I've done in the last 3 months....
Scan Gauge II
Sin Die. Coolant filter
Blue Spring
Oil Cooler 2x, 1st 1 clogged from flushing
CAT ELC Coolant
HPOP
STC
ICP
Rotella T6
Rev-X
MBRP T-Bk No Cat
ICON 4.5"
Toyo 35's
Budget for about $6K in upgrades and you should have a bad **** Truck.
My .02 YMMV
Denny
ARP Studs
OEM Gaskets
FICM Herc Tune
Rear fuel hose.
Vent CCV to Atmos.
Dummy plugs
Banjo Bolts
Stand Pipes
Scan Gauge II
Blue Spring
CAT ELC Coolant
HPOP
STC
ICP
Rotella T6
Rev-X
MBRP T-Bk No Cat
ICON 4.5"
Toyo 35's
My .02 YMMV
Denny
Mainly let it cool before shutdown its a Great Idea to watch it with a Gauge
I just dont see to many turbo getting cooked say like a guy hits 1600* and then says Crap hit the Fan at that point
I run an evil Edge tuner in the 100 HP tune at all times, cept towing.
I've got almost 300k and have been running it awhile now. No studs...
Not saying nothing will ever happen, but it's a risk you take on any tuned vehicle. I've not had anything I would consider tune related repairs yet...
No its the Turbo that have to watch the Temps for mainly I might be wrong but to hot and the turbo cooks the oil
Maybe a Slight risk with an EGR Cooler but if it has good coolant flow the hot EGR Gasses should cool ok
other than alittle Hot exhaust gas going threw the EGR System all the Hot exhaust goes to the Turbo and then out the Tailpipe
I am not studded. I've been tuned now for about 6 months with SCT GearHeadz Matt's SRL tune. I installed a 5'' turbo back, fuel PSI gauge, & EGT gauge before throwing the tune on. So much more power now & trans shifts like a wet dream. Like a shift kit when you get on it. I got on it only a few times since tuning it, but know its there if I need it. I actually like Matts 8K tow tune too. Not as hot of a tune as the SRL but with the same great trans shifting characteristics. If your not going to beat the **** out of it I would do it but if you have self control issues I would stay away because you may end up having to put studs in it real quick then!
If you don't dog on it too bad I think you should be alright. Personally I'm not taking the chance, because worst case scenario I don't have the money for studs right now.
Also, a lot of guys that blow the gaskets are really hard on their trucks. I saw someone post the other day they were pulling a fifth wheel uphill and for like 10 minutes straight just had the pedal to the floor. A couple other guys replied and said they do the same. I was shocked that our trucks could handle that, I would never put mine through that kind of torture!
