Headlights saving MPG??!
#31
i always was under the impression that the ideal conditions would be if it was REALLY REALLY foggy out, like 100% humidity.
then the moisture in the air would cool off the combustion, similar to running meth injection, allowing more boost in a diesel or more advance in a gas engine.
but i was never sure if the extra "thickness" of the air would override this enhanced combustion... i am sure it would though...
air resistance increases with the square of speed, so even a minute increase in air resistance would be a big increase in resistance.
as for the headlights, they simply use less energy (watts) than standard headlights.
if you drive exclusively at night, you might consider them, but if they cost more than a few bucks more than regular bulbs, i'd forget it...
normal headlights are 55w on low and 60w on high
1 watt = 0.00134102209 hp
do the math based on how much watts you save on your bulb type.
then take your horsepower savings, multiply by hours used, and you get hp-hr. convert this to BTU.
then divide by 114,000 to get gallons of gas saved. there are 114,000 BTU/gallon of gasoline.
EDIT: this is 100% gas, for 15% ethanol, it is more like 111,000 BTU/gallon
on their chart, it says you can save $6 with the 9004 bulb... is this over the lifetime of the bulb? per year?
not worth it
you'd save more money using 35w HID bulbs, but then you have to buy the kit... and the weight will reduce your mileage...
your best bet is not to drive
#32
One question I have about these new headlights; how many hours will the work before burning out compared to the factory bulbs. If I'm not mistaken the life expectancy of these new bulbs is much less than factory bulbs, therefore they will need to be replaced more often which will end up costing much more than the factory bulbs.
Mike
Mike
i have never gotten more than 1 year of life out of SUPERSTAR bulbs. but they claim to be like 50% brighter
either way, when you attempt to get more light from less power, your lifespan is affected.
in the words of admiral Ackbar,
ITS A TRAP!
#33
I think I will stay with the OEM, cheaper in the long run and from what I've read the yellow light from a halogen bulb penetrates darkness further than the blue/white light from an HID bulb. That seems to be the case when comparing night driving between my truck and my wife's car with factory HID headlights.
Mike
#34
Pappy, you're missing a very critical aspect of the alternator.
An alternator is a set of spinning electromagnets (the field coils), inside a housing of electrical coils called the stator.
Suppose the alternator is spinning at 3000 RPM. No power is being applied to the field coils by the voltage regulator. No power is being generated by the alternator.
Now take the same alternator spinning at 3000 RPM and the voltage regulator applies voltage to the field coils. A spinning electrical field is created that cuts the stator coils of the alternator and electricity is generated.
In short, the alternator is NOT always generating electricity based on it's RPM. It's generating electricity based on the amount of power the voltage regulator applies to the field coils. If the VR says no power is needed, no power is generated and no drag occurs on the alternator. When the VR decides power is needed (battery voltage is low), it applied power to the field coils, electricity is generated and drag on the alternator is increased proportionally.
The Alternator ( A ) is spinning along at x rpm and is capable of producing 100 units of energy ( E ).
Then a device is turned on and it wants 50 units of that E.
A obliges, but works harder to maintain that 100 units of E.
That work becomes more magnetic drag on A. A becomes harder to turn.
That extra E means the engine must work harder.
Right????
#35
I think I got it...and I'll say it as simply as I can.
Right????
Right????
The voltage regulator simply measures the current voltage and requests more or less electrical output to maintain the battery voltage between about 13.2 to 14.1 volts.
#38
this is something i have always wondered about myself...
not worth it
not worth it
I am too lazy to do the actual math, but using some guesstimations, I think their claims are quite feasible.
On the humidity: Yes, more compression is possible, so more efficiency is possible. But the air density will more than offset the gains.
#39
25 years in aircraft avionics backing up this opinion:
Used 2 wing flood lights from a DC10 on an 89 Jeep Cherokee. FYI they are great for off roading. They are 250 watts 13 VDC each. At idle the 4.0 Cherokee with an RPM of 700-800 when the DC10 wing flood lights were turn on RPM would drop 200 RPM. You can purchase those, by the way from AirCraft Spruce and they are really resonable. I used relays and switches due to the amp draw, they would melt the switches otherwise. GE-4313 Expect $25. each 250W divided by 12/14 Volts = 20 amps.
"HEADLIGHTS WILL LOAD DOWN AN ALTERNATOR." Loaded alternator = loading up the eng. Nothing is free. Takes power to make power.
The nice part is that hibeam runners would dim their lights when I threw those switches on.
#40
A technical marvel from my area. Light bulb that is on constantly for over 110 years. Can you imagine all the billions of $$$ we spend in those 110 years buying short lived light bulbs?
Centennial Light - Wikipedia, the free encyclopedia
#41
if they have lower wattage but generate more light, then they must have a thinner filament. the higher resistance would generate more heat and therefore burn out faster.
if by "bling bulbs" you mean HID bulbs, they are usually 35w or 20w less than standard halogen bulbs.
the other kind of "bling bulbs" are high wattage halogens, and pull something like 100 watts on occasion.
they not only burn out quicker, but can melt your wiring in your car.
#44
correct me if i am wrong but isnt 750 watts one horse so really it would prob take a lot for the excursion to see any notice different. i am almost all led bulbs every where in the X and i still havent seen any.
question what would u think if you put a compasitor on would that do anything?
#45
That's what I thought; my 2000 F250 still had the original bulbs in it when I traded it 10 years later, the only bulb that burned out on that vehicle was the third brake light. My 2 1/2 year old 2010 has not burned out any bulbs yet.
Mike
Mike
