GM ignition switch in my Monaco RV! Help me get rid of it please!
Old 03-28-2012, 02:01 AM
vacuumbed's Avatar
vacuumbed
vacuumbed is offline
I am buying a 1996 Monaco Executive class A diesel pusher RV. Even though this RV is not a GM, the stupid thing has a GM ignition switch!
I'm a Ford man. I like a Ford ignition key in my hand. Makes me feel good.
I need to get a Ford lock cylinder and ignition switch in this thing and toss the GM one in the garbage where it belongs haha.
So this is a dash mounted ignition switch. I don't think Ford has used them in years. The latest one that I can think of is the 1967-1979 Ford trucks and pre-1969 Ford cars. I think the late model Ford stripped chassis trucks use a column mounted switch.
Does anyone have any ideas of what Ford ignition switch and lock cylinder would be best for this?
Old 03-28-2012, 07:11 AM
JWA's Avatar
JWA
JWA is offline
Received 1,394 Likes on 1,103 Posts
I'm betting Standard Motor Parts (SMP) would have something perfectly suited for you; maybe Dorman too?
Your biggest issues will be how the new switch fits through the dash board hole and its connections too--both easily overcome if you're creative enough.
Old 03-28-2012, 03:04 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,684 Likes on 1,360 Posts
Just get a new GM switch. It probably won't be made by GM, it will be made by a aftermarket vendor who gets them made in China, the same place that makes the replacement Ford switches.
Old 05-03-2012, 08:26 PM
vacuumbed's Avatar
vacuumbed
I pulled the GM ignition switch and it turns out to be the same one used on 67-72 Chevrolet trucks. Lovely
I am going to install a Motorcraft SW-944 ignition switch and a SW-814 lock cylinder and keys. These were used in all Ford trucks up to about 1977.
I don't care what it takes to make it fit, I willl make it fit.
Old 05-04-2012, 03:58 PM
vacuumbed's Avatar
vacuumbed
I just for the Motorcraft SW-944 ignition switch and a SW-814 lock cylinder and keys and the lock cylinder does not fit the ignition switch. Hmmm I wonder if one of those parts are wrong?
broadhek
2009 - 2014 F150
04-10-2017 05:01 PM
graymule
Crossovers
07-24-2015 09:36 AM
87f150xlt
11-07-2004 12:35 AM
ftrain
08-13-2002 10:28 AM
69crewcab
03-01-2002 06:50 PM
Quick Reply: GM ignition switch in my Monaco RV! Help me get rid of it please!
