Ford 6.7 diesel m.p.g.
Varies with terrain, speed, wind, temperature, fuel (bio blend and winter blend), additive helps, cargo, idle time, transmission selector (D, M, or tow-haul), altitude, tires (psi, size), lift kit, dually.
if you think you have a problem we need lots more information. 16 is a normal in town average for average conditions and SRW stock wheel and tire with no lift, summer fuel with additive.
Thanks, we towed home from the dealer in MD to MA. Over 12k empty with a 3k pin weight. It was like there was a small utility trailer back there. LOL. I can't imagine the weight that would slow this thing down....
My display is usually showing around 12.2. This is nearly all town driving and I don't know how accurate the truck's computer is. I'll wait till I've got a few thousand miles on it before I calculate it the old fashioned way. Starting with a topped-off tank, and then running through at least 5 tankfull's before dividing it out.
Here is a post of mine about my recent fuel mileage on a trip from VA to OH:
Ford Truck Enthusiasts Forums - View Single Post - Well........it happened.
It's from this thread:
https://www.ford-trucks.com/forums/1...-happened.html
I have my Trip A that I reset each time I get fuel and my Trip B hasn't been reset for quite a while. I had intended to leave it from the day I got the truck to keep track of all of the mileage, fuel, etc. but had a brainfart in Myrtle Beach SC and reset it by mistake. Currently my Trip B has about 5000 miles on it. If I recall correctly, it's showing an average over that 5000 miles of about 14.9 MPG which includes a ton of driving around town.
Well, actually this is backwards. Gasoline prices are finally getting back up to the diesel range. Diesel never went down much when the gas finally started dropping. But since the prices have started rising again, at least diesel hasn't risen in conjunction with gas. It's only gone up a little, while gas has gone up nearly $1.00 a gallon. It's almost caught up to diesel.
On my 09 V10, I had a tuner and need to run 93 so the cost between diesel and gas isn't too far apart. Going from 6-7 towing and 9-10 unloaded to 11-12 towing and 17-22 empty was quite the reward......
