1995 F150 351W Build Thread
#122
rebuild advice/oild additive
Hi everyone, i had a few questions.. I am itching to rebuild/replace my 5.8 on my 95 f150. It runs rough, slow, and its tired with 245,000 miles on it. I used restore engine restorer oil additive & lubricant to see if it would help. I don't think its really helping...
first off, i was wondering how long would it take for the oil additive to do it's job if it was effective?
and secondly.. If i didn't have the money to replace the whole engine, what rebuild kit would you all recommend? I see so many different brands etc. and Im lookin for some direction, and if it's worth getting or should i just keep saving and replace the whole engine with a reman..
thanks
J
thanks
J
#123
What you're asking is a completely different topic than was originally posted about, but I'll answer for you.
The additive you put in is a band aid. It's ment to help your engine along so you can sell it.
A long term solution is not in a bottle.
With 240k it's doubtful you'll notice anything at all. It should take about 100 miles or 2-3 hours of running for the additive to get throughout the engine and all the little places like lifters and rear main seal area. It will help... How much is depending on how worn out your engine really is.
You'll really need to pull the whole engine to be able to do any worthwhile work. But at that mileage, it probably needs to be bored, because if the cylinders are egg shaped, new rings are a waste. You can still do it. It's your truck. But for that many miles you should look into getting the engine replaced or send to a machine shop for work to be done.
Start a new thread and it will be more beneficial for you in the long run.
#125
#126
#127
#128
no build thread, just hazy memories of late nights and beer drinkin. Sorta how it always goes....All the parts I used for 4x and trans were basically off the shelf and oem jy parts short of the pedal assembly, whose design i stole from a guy with a white van zf build thread thanks to google.
#129
Just to say it I did the seafoam treatmenbt to a 95 351 with 112K on it. It dislodged carbon (I assume) and took out two cylinders :/ Ill never do it to a unknown engine again.. However do it to my toyota all the time and it keeps her ticking clean. I chock it up to bad luck but feel the need to share. Was a good engine before I opened that bottle...
#130
#131
#133
#135
