Whats a good exhaust for me?
Old 03-25-2012, 06:01 PM
brcwelding's Avatar
brcwelding
brcwelding is offline
I have an 88 f250 with a 351w. I was wondering if any of you guys have any good exhaust setups. I am not looking to do headers but let me know what you guys have.
Old 03-25-2012, 06:57 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,172 Likes on 926 Posts
Factory manifolds, Bassani 3" y-pipe, 3" Magnaflow converter and muffler. Then finished off with a 3" aluminized tailpipe, please do not tell my truck it was designed for a Chevy.....
I blew my budget on the 3" stainless Bassani y-pipe, hence the reason why I am still running factory manifolds.
1992 F350 4x4 5.8L/E4OD
Old 03-25-2012, 09:37 PM
Scooter70's Avatar
Scooter70
Scooter70 is offline
I kept everything just changed the muffler.I went with a Thrush welded. Nice mellow sound.
Old 03-25-2012, 10:35 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
My last set up on my 351w was stock manifolds, stock piping up to where it was supposed to be a y. Made a better flowing y pipe into 3" pipe then into a 3" single in single out flowmaster 50 series and a 45 out behind the passenger rear tire. Sounded like a mustang with a 302 if you cut off the exhaust after the cat on it. No crackle or pop. Mellow under 3000 rpms and a nice roar after that.
My current set up is a set of long tube 3" collector dynomax headers into a 3" single in single out summit street and strip muffler then it goes to a 45 degree angle out before the rear tires. Sounds a lot meaner and lower, but still decent at low rpms. The headers with the full 3" pipe and lack of tailpipes freed up a ton of power. You can tell a difference in the seat as well as in the pocket. gained 1 mpg average swapping to the current set up.
Old 03-26-2012, 05:19 AM
brcwelding's Avatar
brcwelding
I like the y pipe into the 3 inch pipe. If i fid that i would probably use a flowmaster 40 and just cut the cat off. Anybody have a good dual exhaust setup.
Old 03-26-2012, 09:27 AM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
My current exhaust is dual. I should have been more descriptive.
Old 03-26-2012, 10:29 AM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
I cut mine off just before the cat ran a piece of 3" pipe into a 3" in flowmaster super 44 and a 3" turndown directly after muffler which is just infront of the rear axle.
Search "thebudmiester" in YouTube i have some exhaust clips there
Old 03-26-2012, 10:38 AM
Ole' gray's Avatar
Ole' gray
Ole' gray is offline
Mine is catless, factory piped into 2 cheap glass pack, rumbles at an idle, and roars past 3k, easy and doesnt sound bad
Old 03-26-2012, 02:32 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
I have pacesetter full length headers, custom Y pipe with magnaflow cat and a super 44 dumped after axle.
95 zebra bronco 351w headers exhaust - YouTube
Old 03-27-2012, 07:32 PM
brcwelding's Avatar
brcwelding
What do you guys think of a y pipe into a single 3" then a single in single out magnaflow muffler then dump it in front of the rear wheel.
Old 03-27-2012, 08:49 PM
rla2005's Avatar
rla2005
There are a bunch of exhaust sound clips of different combinations here: Exhaust sound clips - FSB Forums
Old 03-27-2012, 08:51 PM
05victorylly's Avatar
05victorylly
05victorylly is offline
I run a 2 1/4" -> 3" flowmaster y pipe with flowmaster 40 series muffler. No cat
Old 03-27-2012, 09:13 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
If I were you, I would get the exhaust out from under the truck. As in aim it out the side somewhere or out the back. The single 3" will bring up torque though.
Old 03-27-2012, 09:19 PM
Ddaybc's Avatar
Ddaybc
Ddaybc is offline
I've got a 94 with a 5.8 and factory manifolds, Y pipe and cat. 3" from the cat to a magnaflow and then 3" out to the rear of the truck. Sounds great and I make good power. It's a simple and inexpensive exhaust. Not sure if the truck gained any extra mileage with my setup as my dad did it before he gave me the truck.
Dave
Old 03-27-2012, 11:41 PM
Midnite1987
Mines dumped right infront of the rear axle. The closer to the end of the exhaust (right before the dump) the louder it will be as well. Mine dumps right after TW muffler
Quick Reply: Whats a good exhaust for me?
