Cab has air whistle athigh speed
I'm almost done with my '56 big window restore. In test driving, there are loud whistles coming from thefront of upper doors or windows at 60-70 mph. How do you diagnos where the leaks are and how do you fix the problem? I can't feel any air coming through with my hand.
It's all part of the charm of driving an old truck. If you want quiet, buy a Lexus.
But seriously, folks, there's too many edges, dips and gaps exposed to the airflow that no matter how tight you seal your doors and windows, they'll never be quiet. You can try stuffing paper towels, etc., in the windows and door gaps inside the truck while you work through the process of elimination. You can try putting masking tape over the drip rail leading edges up the A pillar and across the roof edge. But you'll probably find the efforts will be futile. A better suggestion; invest in a better radio.
If you finger it can you get "Dixie"?
Seriously, if you are sure it's the doors, first open them and check all the way around for any holes or openings. Is the weatherstripping in good shape without cracks, folds or compressed sections? Cut some printer paper in thirds the long way, put a strip in the door opening and close the door. If you can pull the paper out easily the weatherstrip is not sealing. Check all the way around. Does it whistle all the time or only when the cowl vent or fan is on? Try temporarily taping over the cowl side louvers and see if that helps, pressurizing the cab will make almost any car whistle, the pickup cab is a small volume so it is especially susceptible to pressurization if the air has no way out.
