Redhead Steering Box Group Buy
I did find an ex owner extremely happy with his box, who talks about installing it: https://www.ford-trucks.com/forums/9...-gear-wow.html
And a nice tutorial thread with pictures and lots of discussion:
https://www.ford-trucks.com/forums/8...installed.html
But I found no mention of a quicker ratio box being available for the super duty, so I called Red Head and asked, and was told that no quicker ratio box is available for our trucks. :-(
I waited on hold for about 7 minutes, and the guy that answered said no quick ratio option is available for our trucks, but that what they do will tighten up the steering so it may feel a little bit quicker... he sounded like he really wanted my business even though they couldn't quicken the ratio.
Sarcasm aside, nobody had mentioned steering ratios so I felt that it was worth bringing up. I was "just saying."
Good info.....and if you need more power for larger tires the SD boxes are the way to go. Count me in please!
While idling, put the trans in neutral and let off the brake, do you have power steering now? My 05 at idle with the brake on will only allow me roughly half a turn before I can't turn it anymore. It has to do with the steering geometry. The tires need to rotate in order for the steering to rotate further. Not sure how this changes with suspension mods.
#29
Where are these ratio numbers coming from? The only ratios I ever remember anyone talking about is steering wheel turns to lock ratio. Like a mitsubishi evolution has a 2:1 ratio which is two turns of the steering wheel puts the wheels from lock to lock. My honda civic has a 3:1 ratio.
I did notice instantly when I started driving the X that it has a much less ratio (more turns lock to lock) than what I was used to for years and years in for trucks and to this day it kind of pisses me off. I like quick steering, I don't like having to turn the wheel a half a turn while on the highway just to make a slight curve in the road.
I asked before if the older 1980-1997 F250 and up boxes would work on our trucks? I didn't get an answer then, hoping someone can answer? I would love to have the old ratio back!
