1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Calling all those with Rancho 9000XL shocks?
Old 10-26-2012, 02:38 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Alright, I know it's been a while but I just ordered up the shocks finally. Also ordered a steering stabilizer so maybe that will help too. The are running a buy 3 get one free deal so it wasn't terrible. $393 shipped to the house for 4 shocks and the steering stabilizer.
  #32
Old 12-05-2013, 09:53 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is online now
Received 3,347 Likes on 1,754 Posts
Originally Posted by KC8QVO
I looked in to my system loosing pressure again last night. Before I was looking at all the hoses for a leak around every fitting.
There was a leak around where the fittings bolt up to the shocks themselves. I hosed down all the fitting housings with soapy water and sure enough that's where I found my problem.
The downside is that leak was enough to let water in so I had to clean out the piston a bit along with the O-ring. The O-ring was still in good shape. I gave everything a coat of grease (O-ring track on the fitting, popped the O-ring on, greased that, put some grease on the inside shock track, as well as the gasket). It took two attempts to get the O-ring to seat properly inside but I got it.
I will post back with how it holds up. I hosed everything with soapy water again after the fix and no bubbles anywhere. We'll see if I did any good.
Steve, it's been about a year and a half now since you promised you would post back with how your myRide system is holding up. Well, how's it holding up?
norm805
27
05-09-2022 05:09 AM
2piecespecial
6.7L Power Stroke Diesel
27
09-02-2013 10:32 AM
Ted Bell
10-19-2010 07:58 PM
docgreen
09-14-2004 05:04 PM
98ebexpy
1997-2006 Expedition & Navigator
07-18-2003 01:16 AM
Quick Reply: Calling all those with Rancho 9000XL shocks?
