Modular V10 (6.8l)
1999 v10 performance parts
Old 03-10-2012, 10:37 AM
zakarehamrick's Avatar
zakarehamrick
zakarehamrick is offline
I have a 1999 F250 with the 6.8L V10 in it and I'm trying to find performance cams and all the topend stuff and I can't seem to find any of it anywhere anyone have any ideas on where I can find the parts I'm looking for
Old 03-10-2012, 11:03 AM
Tom's Avatar
Tom
Tom is offline
I think you might have a harder time than most with that one, as the '99 V10 was the only year made without the PI heads. I'm moving this one to the 6.8L V10 forum where you should get some better replies.
Old 03-10-2012, 11:14 AM
Ironhand03's Avatar
Ironhand03
Ironhand03 is offline
I thought the PI and NPI could use the same cams? whats the difference between the two?
Old 03-10-2012, 11:17 AM
Tom's Avatar
Tom
Tom is offline
Perhaps they can, I was assuming that the flow differences between the two would necessitate a different cam.
Old 03-10-2012, 11:19 AM
Ironhand03's Avatar
Ironhand03
Thats nothing porting wont take care of. I was speaking of geometry of the cam, follower, and lash adjuster.
Old 03-10-2012, 11:34 AM
Ironhand03's Avatar
Ironhand03
Almost forgot.
Yes I know where to get all of your top end parts.
Old 03-10-2012, 01:37 PM
zakarehamrick
Where at I new then very soon. I dropped a valve need to redo the whole top end and need the truck running ASAP
Old 03-10-2012, 01:44 PM
Ironhand03's Avatar
Ironhand03
Do you have an email address so I can send you all the info?
Old 03-10-2012, 01:45 PM
zakarehamrick
Old 03-10-2012, 01:54 PM
Ironhand03's Avatar
Ironhand03
Email sent.
Old 03-12-2012, 09:50 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
A few technical points:
The '99 has non-PI heads, but PI heads can be bolted on as long as you take care of a few things.
1) Need the PI intake.
2) Compression will go up, somewhere near 10.25:1 if I recall correctly. That needs to be dealt with by using a custom tune. I think Mike at 5-star can help, he did a PI head swap on a '99 V10 already, so he has a baseline to start with.
A few other points:
No one makes cams for the V10 - Comp Cams I believe used to have blanks that they would machine to your specs, but I don't think they have blanks anymore according to some people here who've tried that route.
Old 03-13-2012, 11:47 PM
Ironhand03's Avatar
Ironhand03
A few other points:
This isnt true.
Old 03-14-2012, 06:29 AM
JWA's Avatar
JWA
JWA is offline
Received 1,410 Likes on 1,112 Posts
Accidental Post!
Old 11-13-2017, 06:05 PM
Elwayno21's Avatar
Elwayno21
Elwayno21 is offline
could I also have this info?
mdrobnak
Modular V10 (6.8l)
03-04-2022 05:19 PM
krewat
Modular V10 (6.8l)
07-07-2010 10:26 PM
N20Jnky
Modular V10 (6.8l)
11-10-2008 02:04 PM
ExcursionUSA
07-19-2007 05:04 PM
Quick Reply: 1999 v10 performance parts
