Been doing some block sanding, found some low spots I missed, that is the whole point i suppose!
Getting very close, should be able to finish up the block sanding and seal it this weekend.
Hope to paint it over Thanksgiving weekend!!
Still got a lot of work to do though, haven't done much with the hood and still have to get the dash ready too.
The hoods on these things are damn big.
I was able to get 2 coats of base sprayed today after pulling out of the garage and washing it, thanks for the help Greg!
The base went down great, I really like this Matrix System paint.
The body definitely isn't perfect, but my first job of this size I am happy with it.
I will be spraying the pearl tomorrow night after work.
Laid down really nice, has some orange peel, of coarse, that was expected.
I still have to clear the hood, but the base and pearl are sprayed on that.
The rest of the Bronco has 2 coats base, 3 coats pearl and 2 coats clear.
Here is the result after wet sanding from 1200 to 4000 grit, then buffing, I am ecstatic with the finish.
I have wet sanded the whole body, still have to do the hood, I have only buffed this quarter so far.
