Dash Wiring Diagram
Dash Wiring Diagram
Im looking for a wiring diagram of the dash. My heater isnt working the Blinkers inside are solid however the blinkers still work. and the windshield wipers wont work I think this is all related by a common harness would someone help me please
My truck is a 1995 F-Super Duty with the 7.3 powerstroke
Welcome to FTE ...
This should get you going in the right direction.
1996 Bronco/F-Series Workshop Manual
I posted a bunch of diagrams for a 97 f350 not sure if it will help. i was able to use some of them on my f250 and they did work for me.
https://www.ford-trucks.com/forums/1...o-links-4.html
on
1 Post
on
1 Post
I'd change the multi-function switch and see if that cures the turn signal and wiper problem, and for the blower, that could be a bad resistor.
on
1 Post
With it all happening at the same time it could be a common problem. Maybe there is a short in the multi-function switch that's messin with the blower. I keep refering to the m-f switch cause mine did something similar with the signals and wipers and that's what it was. If you could get one off another truck to try and see if that's it before buying one would be the way to go.
Builtfordtough001
12-01-2015 09:57 PM
Building_Fords
10-27-2015 08:06 PM
martyanderson10
01-25-2015 05:27 PM
