yup another mpg thread sorry
If your talking about a timing lite for the 300 why not use a vacuum gauge? That's all I use anymore and it works great. Apparently my harmonic balancer has slipped, which I have read is a common problem with the 300, and that was my only option. It's a lot easier than the light is I think. Just hook it up, set timing to maximum vacuum then back it off 2-3 points.
The (only) advantage of a timing light approach is this: using a vac gauge requires adjustment of timing, since you have to adjust to know if you are pulling maximum vacuum or not. With a timing light, if you have faith in the timing marks, you can check timing and know without adjusting anything if you are close or not to correct timing advance. I could be wrong, though.
Probably a stupid question but am a ask . How much does warm up affect mpgs? Not shore about how mpgs are influenced but I let ol blue warm up for a long time at least 15-20 minutes . Hit the throttle one time to disengage the choke an ol girl purred like a kitten she ran sooooo smoothly.
So today didn't do much but got the lookin around on my truck an I realize my truck doesn't have a kickdown cable. That connects the carb and c6 transmission. Would that have an adverse affect on my mpgs? I always felt my truck shifts layed back and lax and late . I was goin to look into that . Goin to borrow a timing light to check that out. An the Duraspark conversion is soon to come soon as I get come cash .
the past few days my truck has been running rather good. good power great idle still poor mpg. all i really did was continue playing with the air idle mixture screw, replaced the fuel filter and added some fuel treatment. i also have really been letting the truck warm up properly ( i think that was one reason for the irratic idle) so my bad for that. i have really been ***** footing the truck never driving above 35mph. and i calculated my milage and i am still getting 10.31mpg. i have yet to check timing. i have been soo busy these past days. anymore suggestions i will be glad to take. thanks guys.
Seth_84F250
25
12-17-2013 08:22 PM
geleonardjr
13
10-02-2007 04:47 PM
