Build Thread: '49 F321
Old 05-03-2014, 07:38 AM
DougofMontana's Avatar
DougofMontana
DougofMontana is offline
NICE work on the running board Jeff! Mine are both in the same shape. Now to find a sacrifice RB!
  #392
Old 05-03-2014, 11:15 AM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Jeff and Nicolle is offline
Yeah thanks for the comments!
I will finish the patch today and show you the end result!
  #393
Old 05-03-2014, 11:23 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
What are you going to use for the underside reinforcement?
  #394
Old 05-03-2014, 04:47 PM
homade's Avatar
homade
homade is offline
Jeff, better make them strong, I think I weigh 300 now , don't want to fall through when I get in to drive it, ha ha , Garry
  #395
Old 05-03-2014, 06:28 PM
topmoo's Avatar
topmoo
topmoo is offline
Great looking work. All the ones I have seen have rust in the same exact place, right where the underneath supports are. I was thinking about replacing mine with fiberglass ones just for that reason. But then I realized that I wont be here for another 60 years so I probably don't need to really worry about it that much...
  #396
Old 05-04-2014, 03:48 PM
Jeff and Nicolle
Ross, I have a used support in great shape if I can get it removed without ruining it. I have also noticed light duty fence posts at Menard's with a similar shape. Hopefully I will get the original one apart.
I also thought about welding 1/8" thick metal strips up under the ribs, but worry about trapping moisture.
Garry if you did fall through. it wouldn't be far! less than a "foot"
I am not sure I will be happy with the repair patch idea, but in my case, I should be able to make it work. I could buy fiberglass also, but I have an 8' Express bed with F1 rear fenders, so I would probably end up needing modification regardless...
  #397
Old 05-04-2014, 03:56 PM
Jeff and Nicolle
All I did was finish welding, grind it down relatively flush, cleaned up the area and shot some ****-can primer on it, for now. Just to help see what it looks like.
I should have spent more time making sure it was absolutely a flush fit. not horrible but not perfect by any means...I will have to spend some time on it yet, but I go out to my big construction project tomorrow, so I am limited on time right now...
  #398
Old 05-04-2014, 04:59 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Jeff,
It looks great!! It doesn't have to be perfect - it's a 60 year old truck!
Looks like a good job to me. Take it easy over there - It was great seeing you back at it.
Ben in Austin
1950 F1
  #399
Old 05-04-2014, 07:41 PM
topmoo's Avatar
topmoo
topmoo is offline
^what Ben said. Looks great to me!
  #400
Old 06-02-2014, 09:42 PM
schoo's Avatar
schoo
schoo is offline
Just read your thread for the second time I like it a lot good info
Keep at it
  #401
Old 06-05-2014, 07:01 AM
Jeff and Nicolle
Keep at it
Thank you. My job has brought me to a stop. But it will be there when I get back in December. Hwy construction project away from home...ugh..
  #402
Old 06-23-2014, 02:09 AM
PRG3216's Avatar
PRG3216
PRG3216 is offline
cant wait till December to see your progress. Great post and great job!
  #403
Old 07-15-2014, 04:15 PM
polarspeed's Avatar
polarspeed
polarspeed is offline
Hello Jeff, Great job you are doing. I am excited to see how you route the exhaust. Is that H-pipe set up that you showed earlier similar to the Summit shorty H-pipe for off road mustangs? I am looking at that and wanted to see how it worked in the truck. Thanks and keep up the good work. Steve
  #404
Old 11-24-2014, 04:10 PM
ford_pickup's Avatar
ford_pickup
ford_pickup is offline
Hoping to see updates soon, just found your thread and you are doing an awesome job
  #405
Old 11-24-2014, 07:40 PM
DougofMontana
Jeff, I have my Jag IFS up and under the frame, pretty much ready to weld in. Question: Did you use stick or wire? I'm not seeing how I can get my wire nozzle down in between the outside of the frame and the cross-member.
Quick Reply: Build Thread: '49 F321
