89 f250 351w no spark
Old 02-29-2012, 10:13 AM
gordsp's Avatar
gordsp
gordsp is offline
My truck died while idling no previous starting or running issues. It will not start I replace ig coil, cap, rotor, plugs, main relay and fuel pump my plug wires are less than a year old I put a plug in the wire that connects to ig coil and there is no spark present any ideas?? I'm 1500 miles away from home need to get it going my next guess is the pick up in the dist right track or no?
Old 02-29-2012, 10:35 AM
88n94's Avatar
88n94
88n94 is offline
I suspect the ignition module on the side of the distributor. With the right SPECIAL TOOL you should be able to remove the module without pulling the distributor. Beings you have a complete won't start condition, the module should be able to be effectively tested. It's very common for the module to fail on these model Ford engines.
Old 02-29-2012, 11:54 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Old 02-29-2012, 12:19 PM
gordsp's Avatar
gordsp
gordsp is offline
Would this module failing cause the truck to shut off while running? Thanks for the tip and quick reply
Old 02-29-2012, 01:01 PM
88n94's Avatar
88n94
88n94 is offline
It certainly would.
Old 02-29-2012, 01:11 PM
gordsp's Avatar
gordsp
gordsp is offline
Do I need to take it off of the ddist or can I just get a new one and plug it in?
Old 02-29-2012, 01:17 PM
rla2005's Avatar
rla2005
rla2005 is offline
That would be dangerous to do for any length of time. The distributor housing functions as a heat sink. For a short test you could plug in the new one to see if you get spark.
If you would reference the link I sent earlier you would have a good idea if the PIP or the TFI was at fault. Aftermarket TFI modules tend to not be the most robust in the world. It is recommended to get a Motorcraft brand for best results. Of course, they are the MOST expensive.
Whenever you replace or remove a TFI you will need to make sure the back side of it has a good coating of thermal compound. Not to be confused with dielectric grease. Two different animals.
Old 02-29-2012, 01:19 PM
88n94's Avatar
88n94
88n94 is offline
You need to take it off the distributor. There are 6 or 8 flat prongs that plug in under the distributor. After you remove the two mounting screws with the special tool, pull down on the module to remove it. Be sure to put the special heat sink grease on the flat spot behind the new module.
Old 02-29-2012, 02:30 PM
gordsp's Avatar
gordsp
gordsp is offline
Sounds good just grabbed it so I'll give it a shot and post if it works or not cost $60
Old 02-29-2012, 04:19 PM
gordsp's Avatar
gordsp
gordsp is offline
No go that unbeleivable it'll be a brand new truck soon or burned
Old 03-01-2012, 09:53 AM
gordsp's Avatar
gordsp
gordsp is offline
I 've heard there might be a way to jump it using a wire from battery to ig coil anyone know anything about that? Any ideas would be apreciated should I try the pick up in dist?
Old 03-01-2012, 11:36 AM
rla2005's Avatar
rla2005
rla2005 is offline
Invest in a cheap DVM. It would have paid for itself already. SBFTech.com TFI Module/Hall Sensor Testing Procedure
You can use the same DVM to verify you have +12VDC on the positive side of the coil. There should be a small metal capacitor tied to that supply line, mounted on or near the coil. I have seen it short out internally and drag down the supply voltage. Try unhooking it.
Old 03-01-2012, 11:45 AM
88n94's Avatar
88n94
88n94 is offline
I would turn the ignition switch on and check to see if you have power to the small wires on the coil. If you unhook the wires from the coil to test, you will only have power to one wire. Don't forget to turn the ignition switch on. If you have power to the coil, I would pull the distributor out. Mark or note the position of the rotor and also the position of the distributor body in relation to something. A good shop should be able to test the whole distributor for firing. Hopefully install a new ignition pickup(stator) so you won't have to go with an infamously bad rebuilt distributor.
Old 03-01-2012, 12:49 PM
gordsp's Avatar
gordsp
gordsp is offline
I have tested for power to the coil I have the 12v looks like its either going to the shop or spend the 30 on a pick up also just found my neg battery cable was rotted through figured it was shorting out so spliced it still nothing I'll try unhooking that capaciter and see what happens thabks for the tips would like to sort this out for myself and others seems like a pretty standard problem
Old 03-01-2012, 02:38 PM
rla2005's Avatar
rla2005
rla2005 is offline
Yes it is a very common problem that can be diagnose with minimal tools. That is why I keep hammering you to diagnose the problem with the proper tools, cheaper than the TFI you purchased, and quit throwing parts at.
We are just trying to help you. You can choose to take our advice or proceed however you like
Quick Reply: 89 f250 351w no spark
