i have a 90 f150 with the 302 auto. i was driving home from work and the truck shut off, it took 10 mins to start back up and when it did it ran like crap. i had orilleys run a test on it and the egr valve needed replaced. i did and no luck, i replaced the plugs wires cap and rotor, i also fixed the oil leaks (valve cover gasket and oil pan gasket), at this point i dont know what to do, has any one had the same problem
there was an egr code but that is gone now, there is nothing else, fuel pressure is at 42 psi, i am going to do a compression test, do you know what it should be at
