Windshield in before paint??
Gonna finally be Painting my truck after about a year and a half of doing rust repair and bodywork. You think it would be a good idea to put the windshield and back slider back in before final color goes on, or paint, then install glass?? Was just curious cause don't wanna be scratching up things trying to put them in?? Any suggestions??
If the windshield is out then paint away and have the glass installers be careful with there install tools and tricks, nothing worse than a new paint job and a even newer scratch. DUH
If it in and you want or need to leave it in (new seal and glass) and do not want to risk a break or pay again $$ for a removal just to paint).
I have heard of a trick to hold up the outer edge of the rubber seal with a piece of string or cord just put it like 3/16th" in or under it all the way around, so the paint will get under it????
Probable only work on a new seal??
Just a trick, not a proven tip, and old painter guy told me this....maybe BS?? Maybe a Earl Scheib/MACCO trick??
Always paint before installation. If you want to wait and do final body pain after glass is added, get a good primer and get some of the paint you will be using for the body and at least spray around where the gaskets will sit. All the prevention you can do in those areas will pay off years down the road.
Yes we all know that, thanks for covering it again, I am only suggesting the other way to save him money in case that is a issue. No one mentioned any other route but "paint with it out".
I like trying to be the other side of the coin and think outside of the box.
Just maybe he got all new glass and seals and said "damn I cant afford to pay for a remove and reinstalled after a new paint job, oh what to do"?
Yea I am sure he can remove and reinstall in 10 min by himself, like all the rest of us right?
Insert (chuckle)
Insert (chuckle)
