Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Diagnostics
- Why is My Truck Losing Power?
Guide to Diagnose trouble and recommended solutions
Rough idle, stalls, loses power after it warms up
I have the exact same symptoms on my 2008 ford f250
I have the exact same symptoms on my 2008 ford f250 superduty 5.4, before doing anything to my truck i would like to know if you could share your experience with the problem you had last year and what was the solution to the problems, thanks in advance.
My solution
I recently had the same symptoms with my truck and it turned out to be a water pump going bad. Go figure, it hadn't even begun to leak around the gasket yet. I replaced it and the truck runs like new. If you can replace it yourself like I did it should cost less than $50. A shop could be anywhere from $150-350.
hey guys im new to owning a diesel i have a 91 ford f350 7.3idi and im having an issue i can start it and run it at idle for as lond as i want rev it up and everything but as i am driving and i shift out of first and into second or if im backing up it just dies on its own i just dont get it oh and it has approximately 935,xxx miles on it
sbxworship
16
11-30-2011 03:34 PM
