Slip-Yoke bump is back after TSB repair what next?
#34
my 2004 F350 did the same thing, i removed the driveshaft and heavly applied Mobil1 grease but my thump didnt go away. I went to the local Ford dealer and baught a tube of blue teflon enriched slip joint grease for six bucks. Cleaned the grease off and packed the slip joint with the blue Ford grease, my truck is now butter smooth and its still going after a year. Id go try the Ford grease, its only six bucks and it works
#35
Took mine in to the dealer and they are going to replace the driveshaft. I didn't ask, but I hope this means the entire two pieces and the carrier bearing. The tech had found burrs, but didn't specify the exact location. I have already had the slip yoke greased one time.
Looking forward to a real solution. Keep your fingers crossed.
They replaced the two piece drive shaft and the carrier bearing.
#37
When my truck was in for repair , they gave me a loaner '12 Super Crew, short box, 4x4, Ecoboost. That truck had the slip-yoke bump too. Only had 1300 miles in it as I recall. Also had a single drive-shaft where my 2wd has a two piece one.
#38
I just took my 2010 in for the same problem and the dealer called me saying i had "transmission failure" thankfully I purchased the extended warranty. They're replacing the clutch plates and a few other components. Hopefully this solves it. A bit extreme to what I thought was going to be an easy fix. I take great care of my truck, so pretty shocked the tranny went out @ 80k.
#41
Yes sir, I would suggest you take it in. It is a known issue for at least a couple years now. Nothing new and your service dept. shouldn't act surprised when you tell them about it. Several TSBs on this very issue.
A simple grease fitting or two on the yoke would seem to be a very simple and logical solution, but it is beyond me why Ford cannot do this. Unless, of course, I am totally missing something.
Mine is starting to do it again and this will be the third time with 32K. The last time a new drive shaft was installed and it has lasted the longest. The first time I had it done was around 7K.
#42
#43
#44
Note: If they say they "cannot duplicate" the problem, request that you have some one take a ride with you and point it out to them. I have had to do this before, because I will not accept an answer of "cannot duplicate."
Good luck, should be a very simple fix.
#45
I had my 09 in for a rear pinion seal earlier this week and had them do the slip bump TSB at the same time. $100 p&l for the seal and $80 p&l for the TSB and she is smooth as silk. He said the splines still had grease on them and couldn't understand how it would be having an issue so we will see how long it lasts. It was the local mechanic that did it because I cannot stand our local Ford Stealer. If it starts again I will try the marine grease and heater hose so we we will see.
