ULSD Cetane Rating in your neighborhood
I was exploring some of stations near my neighborhood today and I found these ULSD Mininum Cetane Ratings.
Sheetz (truck stop): 45 and 42 Cetane
Hess (truck stop): 45 Cetane
Shell (local gas station): 42 Cetane
BP, Exxon, Sunoco, Liberty, Love's (local gas stations): 40 Cetane
Many other stations did not post their Min Cetane Rating on the pump
What do you guys see in your neighborhood? What do you guys think of the quality of ULSD from Sheetz or Hess? I'm thinking of lining up with the big trucks and get my F350 6.7L PSD filled at either Sheetz or Hess. Is this a mistake? Also, should I still add additive with 45 Cetane? Please advise me, and thank you.
Everything in my area is minimum 40. There was one BP station that had minimum 47 stickers up until last week. I didn't mind going a little out of the way and paying an extra 10 cents a gallon compared to the other stations in my area. For some reason, they just changed their stickers to minimum 40. However, of course the price did not change. Still averages 10-15 cents a gallon more than most stations. No, I'm not continuing to buy my diesel there. I've been using additive regardless of posted cetane rating.
EDIT: I think fuel from truck stops should be safe. No worries about old fuel, since they should run through it pretty fast.
Regards
Sincere question...how would one know that the lubricity of any 2% biodiesel exceeds the US mandate of 520 scar? The fuel blenders would not be required to provide data to support an increase in lubricity. The oil industry sucks every available penny out of their products. It makes me wonder if they would leave something out of the mix to save that penny. I know the Spicer report showed the biodiesel numbers to be much better but has there been any tests done on biodisel that show there result was not an anomaly? If 2% biodiesel is the lubricity solution,I would be using it religiously. There is a problem finding biodiesel in Michigan...my area has no sellers.
Regards
Regards
Regards
Regards
If you do a search under biodiesel retailers you will find a map showing 20 retailers selling it in Mi. If you buy 1 gallon of 100% bio that should treat 50 gal. of fuel.
You fill up your truck with 25 gallons of fuel, you add 3 oz. of PM 22A, or your favorite additive. Your next fuel up requires 12.5 gallons of fuel. Do you add 3 oz. of additive again, or prorate the amount of additive to the amount of fuel you just added, since the fuel already in the tank prior to your fueling already has additive in it? Or do you pyramid the additive? Can you get too much additive? How do you figure your additive amount?
I don't mean to ask more questions to answer your question. I'm just trying to understand what others are doing. I personally try to round off closely to the amount of fuel I added and add the proper amount of additive based on how much fuel I just added.
Wow, there's a lot of a's and d's in this post. I guess my wife is probably right, I probably do have A.D.D.
Hypothetical situation:
I always put 8 oz of power service in when I fill up. I don't really care if I add 18 or 24 gallons to the tank.
Good question though, I have had the same thoughts. I generally don't stop for fuel unless it is 50 miles to empty or less so I am almost always within 20-24 gallons of fuel. It's pretty consistent. I do add a tank of un treated fuel every now and then just for kicks.
